Question about Miele CatAndDog700 Bagged Canister Vacuum
Can I fit in both filters?
I have an air clean charcoal filter and a hepa filter. Do I fit them in the same slot, can they be used together?
    President:
  • 1,673 Answers
Yes they can be used together, and they would fit in the same slot if there is room.
Posted on Mar 11, 2008
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
Vacuum hepa gets hot
Carol,
Have you checked to make sure that all of the filters have been cleaned so that you have good air flow? The HEPA filter is your final exhaust filter and if your motor is getting hot because of poor air flow, it will cause the HEPA filter to get hot as well. Hope this helps!
Aug 02, 2015 | Fantom Vacums Vacuums
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
The bottom filter under the canister keeps popping out everytime I vacuum. This is really annoying. The bottom looks sort of dirty but I'm not sure how to clean it.The top looks very clean. I know I need...
This is a pretty clear indication that your filter is clogged and needs to be replaced. HEPA filters are different then say pre-motor filters, or sponge filters. Because they are usually the last filter before the air is exhausted, it's usually catching very tiny microscopic particles. Because of this, trying to determine if the filter is dirty or clogged can be difficult, if not impossible on HEPA pleated exhaust filters.
The fact that your filters continues popping out, indicates that the air is not being able to pass through the filter as it's supposed to, and is instead the air is having to try and find a different way to escape, causing the force of the back up of air to blow the filter out.
I think if you replace this filter, it should fix the problem completely. Because this filter is designed to capture microscopic particles rather then large particles, washing this filter, or getting it wet is not advised, and wouldn't be an effective way to clean it. You really will need to replace the filter soon, but if you'd like to try and prolong the life of your filter, you may use an air compressor, and blow from the top of the filter (the area that looks clean), and clear the microscopic particles, and dust out of the filter this way. If you suffer from breathing issues, asthma, or allergies, I would highly advise against doing this without a mask on. The dust that will come out is extremely fine dust that can cause people with the above conditions to suffer greatly. Doing this outdoors is highly recommended.
An air compressor can certainly prolong the life of HEPA filters, but again, sooner or later you'll need to replace the filter.
If you're in need of buying one of these filters, you're in luck! We carry these filtes on our site, and they are in stock. Here's a link back to the filter on our site if you need to order one. We offer free shipping, 60 day returns, free return shipping, and no restocking fees. Please feel free to reply to this solution by using the comment box at the end of this solution. If you found my solution to be helpful, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated by the FixYa community, and is really what keeps repair professionals like myself to keep answering free questions, and not just the premium questions which we get paid to answer.
http://www.govacuum.com/10662-Hoover-303172002-Windtunnel-T-Series-Replacement-HEPA-Filter-Cartridge.aspx
Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Filter cleaning
use an air gun from a air compressor, that is what i use with mine-Lance
Oct 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Miele Revolution Vaccuum cleaner manual
Under the download section is the owners manual. This is for the same series Miele that you have so this manual will have most everything you need to know. The black filter is a charcoal filter, this is good if you want to control the odor but don't have allergies. If you have allergies you might wont to get a HEPA filter. I would recommend changing the filter every 6 months to a year. You need to use the empty filter when you want to use it as a blower. The hose will not fit into the opening with the HEPA or charcoal filter in place. I hope this helps.
https://www.centralvacuumstores.com/item.php?id=4545#
Jan 06, 2009 | Miele Revolution 600 Bagged Canister...
WindTunnel HEPA Filter won't spin
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Sep 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hepa filter does not rotate
Mar 16, 2008 | Hoover U6630-900 WindTunnel Bagless...
Miele CatAndDog700 Bagged Canister Vacuum Logo
66 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
