Question about Sony PCS-1 (PCS1) Video Conference
Packet Loss and Video Freezing Up
We are experiencing packet loss pop ups and after 10 minutes the screen freezes, where should I start?
We are currently having some problems receiving the video stream from our counterparts in China. Somehow 50% of the total packets gets lost and none are getting recovered. The video becomes so pixelated that you can't even see a clear image of what's in front of you. We have tested several resolution to fix the issue but none were successful. We did changed the bandwidth from 1024 to 4Mbps. Currently our counterparts from China can see our video clearly. We went to our vendor and did some tests at their showroom, to see whether the problem might be with our internet provider, using the same codec (PCS-G50) we did get the same result. They can see us clearly but from our end we lose a lot of packets and see a lot of pixelations and smears. Also just to add we did configure our firewall and set up the IP address of the codec outside of the firewall to avoid any filters and blockages, yet we were not successful. Please help us and see maybe there is way for us to recover the packet loss.
Thanks,
  • artit Mar 10, 2008
    Also we are located in Vancouver, Canada.
Hi artit,
I had the same problem with heavy packet lost after 10 minutes connection between Singapore and USA. We are using ADSL line and Sony PCS-G50 for video conferencing. After a much trouble-shooting, we identified that the nature of the problem lies with the Internet Service Provider's back-end server. The server has difficulties handling large and constant data packets. This could be due to the reasons that ISP using routers with more hops and small pipes. We immediately changed the ISP to a more reputated one (with better infrastructure) and now, we have a much better quality video.
Posted on Oct 20, 2008
    Problem Solver:
  • 3 Answers
I assume that you are running the current Sony PCS-G50 Firmware?
Best regards,
Andy
Posted on Feb 19, 2009
Gjj
Posted on Mar 27, 2008
When a User Connects to Devices Such as a Server Through a Switch, the Connection Speed Is Slow and Packet Loss Occurs Sometimes. Why?
In SV100R001 and SV100R002, packets are discarded when a large number of ARP entries exist on the switch, ARP hash conflicts occur on the chassis switch(such as S3700-52P-EI-24S-AC), entries fail to be delivered, or traffic is slowly forwarded in software forwarding mode. In this case, services are affected. In SV100R006 or later versions, ARP entries are delivered to the defip table after ARP hash conflicts occur. The problem of packet loss is resolved.
Jul 27, 2016 | Computers & Internet
Tip
How do latency and packet loss determine network performance and what can be...
The triumvirate of network performance metrics are packet loss, latency and jitter.
Almost all network applications use TCP (Transmission Control Protocol) to get their data from point A to point B. About 85% of the overall internet's traffic is TCP, of which specific aspect is that it completely hides the packet-based nature of the network from applications. Whether an application hands a single character or a multi-megabyte file to TCP, puts the data in packets and sends it on its way over the network. The internet is a scary place for packets trying to find their way: it's not uncommon for packets to be lost and never make it across, or to arrive in a different order than they were transmitted. TCP retransmits lost packets and puts data back in the original order if needed before it hands over the data to the receiver. This way, applications don't have to worry about those eventualities.
Network latency
TCP has a number of mechanisms to get good performance in the presence of high latencies:
1) Make sure enough packets are kept "in flight". Simply sending one packet and then waiting for the other side to say "got it, send then next one" doesn't cut it; that would limit throughput to five packets per second on a path with a 200 ms RTT. So TCP tries to make sure it sends enough packets to fill up the link, but not so many that it oversaturates the link or path. This works well for big data transfers.
2) For smaller data transfers TCP uses a "slow start" mechanism. Because TCP has to wait for acknowledgments from the receiver, more latency means more time spent in slow start. Web browser performance used to be limited by slow start a lot, but browsers started to reuse TCP sessions that were already out of slow start to download additional images and other elements rather than keep opening new TCP sessions.
3) Also you may use simple open-transfer-close-open-transfer-close sequences that work well on low latency networks but slow down a lot over larger distances or on bandwidth-limited networks, which also introduce additional latency.
4) Try to use a DNS server close by. Every TCP connection is preceded by a DNS lookup. If the latency towards the DNS server is substantial, this slows down the entire process.
Packet loss
Packets are lost in networks for two reasons:
1) Every transmission medium will flip a bit once in a while, and then the whole packet is lost. Wireless typically sends extra error correction bits, but those can only do so much. If such an error occurs, the lost packet needs to be retransmitted. This can hold up a transfer.
But if network latency or packet loss get too high, TCP will run out of buffer space and the transfer has to stop until the retransmitted lost packet has been received. In other words: high latency or high loss isn't great, but still workable, but high latency and high loss together can slow down TCP to a crawl.
2) Another reason packets get lost is too many packets in a short time: TCP is sending so fast that router/switch buffers fill up faster than packets can be transmitted.If TCP has determined that the network can only bear very conservative data transfer speeds, and slow start really does its name justice, it's faster to stop a download and restart it rather than to wait for TCP to recover.
Jitter - is the difference between the latency from packet to packet
Obviously, the speed of light isn't subject to change, and fibers tend to remain the same length. So latency is typically caused by buffering of packets in routers and switches terminating highly utilized links. (Especially on lower bandwidth links, such as broadband or 3G/4G links.) Sometimes a packet is lucky and gets through fast and sometimes the queue is longer than usual. For TCP, this isn't a huge problem, although this means that TCP has to use a conservative value for its RTT estimate and timeouts will take longer. However, for (non-TCP) real-time audio and video traffic, jitter is very problematic, because the audio/video has to be played back at a steady rate. This means the application either has to buffer the "fast" packets and wait for the slow ones, which can add user-perceptible delay, or the slow packets have to be considered lost, causing dropouts.
In conclusion, in networks that use multiple connections to the internet, it can really pay off to avoid paths that are much longer and thus incur a higher latency than alternative paths to the same destination, as well as congested paths with elevated packet loss. The path selecting process can be performed automatically: learnhow to automate evaluation of packet loss and latencyacross multiple providers to choose the best performing route.
on Jan 27, 2015 | Computers & Internet
My skype 6.11.1 outgoing call keep droping
outbound bandwidth usually stinks. shut down anything that may be impacting that. It also gets very quirky when there are memory issues like having a bunch of browser windows open and a download going on in the background (don't forget the auto updates when you're pulling your hair out trying to find it).
Jan 24, 2014 | Skype IM
Will disabling net bios, speed up my network, wile playing Xbox 360 muilti player games speed up my network so that I do not lag and have packet loss?
No, Netbios is essential for your network component to run, without it you would not be able to play anything over the net. In order to reduce lag and or packet loss, you should increase your bandwitdh, cable integrity, and make sure that no one else is piggybacking on your connection.
Oct 13, 2013 | Computers & Internet
Packet loss
assuming that this is happening with BOTH wired and wireless....
Connect a PC to one of the switch ports with an Ethernet cable. Login to the Admin utility of the Router and go to "System Tools" at the bottom of the left-pane. it will expand, then choose -Diagnostics-, then use that to Ping yahoo.com or google.com and see if the packet loss is happening there.
If it *IS* happening there, then the problem is not the Router...it's getting what the modem is sending, so your fault would either be with the Modem itself, or with your service provider's equipment. You would call your provider, explain your packet-loss experience and they will check it out for you.
If there is no packet-loss coming-in to the Router, then :
Ensure that the antennae are straight (if the problem is wireless only.)
Ensure that you do not "stack" the Router on top of the Modem or the Modem on top of the Router. The heat from the bottom appliance will, over time, cook the one on top.
Beyond that, you can "save" the Router's configuration file, then perform a "Reset" of the Router, then Re-load the config file and check it out.....
Tallon41
Sep 18, 2012 | TP-LINK TL-WR941ND Advanced Wireless N...
Packet loss slow internet dell
If you loose packet when you ping your router, is or your router or your network card who made the problem. Try to ping your router with an other computer. If you still lose packet is the router otherwise is you network card. When you know where's the problem you can change the faulty device.
Aug 06, 2012 | Dell Computers & Internet
I bought a DLink DIR 600 wireless router and want to connect ONLY two PC to it. One is wireless and one is wired. No internet connection to www required. The wireless PC OS is Fedora 14, the wired PC...
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Jan 24, 2011 | D-Link DIR-600 Router
Connected, hi packet loss
check your explorer in the internet options and see your connection settings and check if your connection is using proxy, if proxy change in a default...
Jun 17, 2009 | Computers & Internet
Network Problem (occasionally loss)
Are all clients losing connections or just one? Can anyone ping the server when your client is getting 75% loss? If you are using a hub, what traffic is running during packet loss? You might need a packet trace to see what is going on. You also need to check your server stats when it is happening and when it is not and see what the difference is. Check the hub stats for errors on the ports. Is the server on the same hub with your client? These should help you find the problem if you get this info.
May 11, 2009 | IBM eserver xSeries 205 8480
Sony PCS-1 (PCS1) Video Conference Logo
1,020 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
