Question about Mitsubishi WD-62525 62" Rear Projection HDTV
915P043010 have the bulb
Have the replacement bulb, need instructions on fitting it into the housing
  • IBM MAN Jun 04, 2008
    I bought the bulb for this at www.interlight.biz
    They were $200 cheaper than anywhere else
  • bndbob Feb 24, 2009
    just replaced the bulb/cartridge assy tv went throught boot and then red bulb light again? any ideas? bob
Im confused do I replace the bulb or the entire cartridge?.... Bulbs from what I can tell are a lot cheaper than cartridges. The only local place I found that carries the bulb will only sell it to me if they put it in the cartridge for $219(total).....is this a reasonable price or should I just hunt the bulb down and install it myself?
Posted on Mar 13, 2008
  • 42 Answers
Pull the panel off where the speakers are the entire plastic lover comes off. Next, make sure the tv is unplugged and has been off for at least 15 min, preferably longer. See the box with 4 screws take those out... it should have a set of instructions or some sign saying it contains the bulb. Anyway.. after that door comes off, peer inside and you'll see the bulb about 6-8" back and has set screws which must be unscrewed completely before it can come out. Be careful, don't yank the bulb out. Then place the new bulb in, reverse the process I told you, plug the tv in and reset the bulb when it askes if you changed the bulb.
It is really easy on mitsubishi tv's to change them... post back if I can be of further assistance.
bob
Posted on Mar 12, 2008
How do i fit a side front off side bulb in my 2002 ford escort van diesel 55
Instructions
  1. Make sure the the headlight switch is in the off position.
  2. Open the bonnet to the Escort.
  3. Locate the back side of the headlight assembly to the headlight that needs to be changed (driver's side or passenger side) from inside the front the engine compartment.
  4. Unplug the wires from the back of the bulb.
  5. Turn the back of the bulb housing counterclockwise one-third of a turn until the bulb and wire harness are released from the headlight assembly.
  6. Unplug the wire harness from the bulb socket.
  7. If using Halogen headlight replacement and be careful not to touch the glass bulb part. Handle it by the socket at the bottom of the headlight.
  8. Plug the wire harness into the new headlight replacement.
  9. Align the tabs on the headlight housing to the slots in the headlight assembly and insert the bulb into the assembly. Twist the headlight one-third of a turn clockwise until it locks into place.
Dec 03, 2014 | Ford Cars & Trucks
TESCO MTG04ss MICROWAVE HOW DO I CHANGE THE LIGHT BULB?
Unplug the unit from the mains. Remove the 4 screws at the rear holding the cover to the unit, and the 2 screws on the right hand side, then slide the cover backwards to release and remove. On the right hand side near the front there is an aluminium housing with a connector on the top. Bend the front flap back to reveal the bulb. You may want to remove the screw at the top of the housing to make access easier. The bulb is a 240v 20w screw fit. Mine had just vibrated loose, so only needed screwing back in. Once replaced, follow instructions in reverse, ensuring that lugs on the bottom of the cover locate into the unit correctly for a snug fit. Plug mains back in and open the door to check the light works.
Jun 04, 2011 | Ovens
Need fitting instructions for Nokia E63 replacement full housing.
get through your user manual provided with thw purchase of your mobile phone.you can find the instruction for replacement of housing....better to get a help of trained service engineer
Mar 20, 2010 | Nokia E63 Cell Phone
My hitachi 50v720 bulb blew and the replacement doesn't fit
I have a 50V525E and I have the same problem....My bulb is suppose to be a LM500 and I received a P22 Phillips (And I did check their web site and that is the bulb they recommend), and like you said...The 4 little glass tabs will not allow the bulb to sit flat in the housing.....
I am waiting for the vendor to answer my inquiry...But I recommend to anyone ordering a bulb...Ask if it is Phillips, and if it is...stay away.
Steve
Jan 23, 2009 | Hitachi 50VF820 Projection TV
Replace brake light on my 2002 Honda Oddesey passenger side
Open the rear hatch and remove the two taillight mounting screws. These screws are located behind two plastic flaps that are flush fitting and part of the tail light housing. You will need a small flat blade screwdriver to put under the edge of the flap nearest the light. Pry gently (but persistently) and the flap will open to reveal the screw head underneath. (The hinge of the flap is on the side nearest the hatch opening.) Remove the screws with a phillips head screwdriver or an 8mm socket. Now comes the tricky part. Wiggle/pry the taillight housing as straight back as you can. Keep pulling/wiggling until the forward clip releases. Once it does you will be able to access the bulbs by rotating the bulb holders counterclockwise. Pull the bulb straight up out of its socket. Replace with the new bulb. Note how the forward spear point clip fits into its socket at the forward outboard edge of the housing. Fit the clip and push forward on the housing until you can hear the clip snap into place. Replace the screws and fold back the flaps. You're done.
-T
Jan 15, 2009 | 2002 Honda Odyssey
How do I replace a front headlight?
remove the three bolds and one nut holding headlight housing in place. pull out housing turn bulb plug counterclockwise till bulb comes out replace bulb and reverse process to re-attach housing.
Dec 27, 2008 | 2000 Toyota Celica
I believe the lamp you need is the UX21516. not the 21517
I have a 50VF820 and this is the lamp for it.
By the way my unit just hit the 3 years and the lamp just blew as well.
Dec 14, 2008 | Hitachi 50V720 Television
Tail light blinker replacement
Laura E;
Most tail light housings use the same approach. The bulb is removed from the housing by twisting
the back of the bulf where the wires are. Usually the bulb itself has a rubber back and turning it about a quarter turn counterclockwise (remember lefty=loosey; righty = tighty) will release the bulb it from the taillight housing. Take the bulb with you when you go for a replacement to be sure you get the right one.
The bulb will only fit one way into its socket and the socket will only fit one way into the housing.
Good luck ,
Loringh
Oct 14, 2008 | 1994 Ford Thunderbird
Bulb replacement
The instructions should have come with the bulb. Ask the seller for the instruction
May 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
332 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
