Question about Samsung Blackjack SGH-I607 Smartphone
Overheating HELP !! Sometimes the phone gets VERY warm and drains off the battery rather quickly..Just removed the battery and re installed and rebooted..phone is now cool..It will get hot again..Is this a setting issue !!
  • memepuyo Mar 27, 2009
    I have the same problem, so the battery only last fot 2 hours!!! I bought a brand new battery, but the overheating persists... does anyone know what I can do?? who can fix this problem??
My phone does the same thing!!! I read on another site that if the battery had been damaged or been in freezing weather it would damage the circuitry in the battery itself and cause the overheating.It also said that in some cases the battery had actually exploded! I am going to get a new battery and will let you know if it solves the problem.
Posted on Mar 15, 2008
Iphone 5s gets hot and battery drains
This sounds like the battery in the phone has an internal short. This would explain the overheating and fast draining. It very well could just be a rogue app. (If anything was recently installed to change the issue) otherwise all sources point to battery. You can either use your insurance and replace phone, or you can buy a battery kit with needed 5 point pentalobe screwdriver to remove back cover, the battery connector is held down with one screw, it is extremely simple to change and there are countles sguides and videos showing you how-to replace the battery. If you do not feel comfortable opening phone , there are countless repair guys on craigslist or a local phone shop may also do repairs. (It really is so simple though, just three screws to a working phone!) good luck
Sep 05, 2015 | Apple iPhone Cell Phones
Samsung Galaxy proclaim battery overheating
G'day mate,
i reckon you are experiencing a power drain problem, there are few reasons that leads your device to it, check if you've installed any new app or got any new accessories such as your wall charger or a new USB charging cable, if yes, try to take that off your device and see if this help, if this doesn't solve the problem, try update the firmware of it.
Good luck
Cheers
Jan 11, 2014 | Cell Phones
Battery overheating and draining
i think ur phone problem some short circuit problem thats y battery quick draining
Dec 04, 2013 | Samsung Galaxy Cell Phones
Battery heat up quickly on Nokia Lumia 800
This is fairly common with heavy use. If it is hot even to where you can't keep your hand on it, then you may want to replace the battery. If you can keep your hand on it without hurting yourself I wouldn't worry about it.
Nov 23, 2013 | Nokia Lumia 800
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
Sep 17, 2017 | Sony Ericsson - Xperia PLAY Mobile Phone -...
My phone will not charge. I can connect it to the charger and it looks like it is charging. Remove the charger then phone goes off. I charged the battery with a stand alone charger then installed battery....
It maybe a problem on the phone already and not on the battery. Something inside the power ic / board that's why any battery will not hold charge for long. Try also draining the battery and then charging it for a full 2 hours with the phone powered off as this charges the phone faster.
Mar 07, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
Overheating L7
It can be due to the battery getting warm while the phone is used continuously or when the charger is connected for charging the battery. It is possible that a poor battery can heat up when the current is drained.
If the phone by itselt is heating it can also be due to shunting due to poor signal strength or connectivity as the phone HUNTS for the signal therby working with a higher output.
Nov 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Im a female unfamiliar with car repairs. Please help me understand where the thermostat is located in my daughters 1991 toyota tercel.
REMOVAL & INSTALLATION The thermostat's purpose is to control the flow into the engine from the radiator. During warm up, the thermostat remains closed so that the coolant within the engine heats quickly and aids the warming up process. As the coolant temperature increases, the thermostat gradually opens, allowing a supply of lower temperature coolant (from the radiator) to enter the water pump and circulate through the engine. NOTE: A thermostat should never be removed as a countermeasure to overheating problems. This will only decrease the cooling system efficiency and add to the problem. The vehicle cooling system should be serviced with necessary components replaced.
  1. Drain the cooling system and save the coolant for reuse.
  2. Remove the water inlet housing (disconnect any electrical connections on the housing) and remove the thermostat. Carefully observe the positioning of the thermostat within the housing before removal.
  3. Install the new thermostat in the housing, making sure it is in correctly. It is possible to install it backwards. Additionally, make certain that the air bleed valve aligns with the protrusion on the water inlet housing. Failure to observe this placement can result in poor air bleeding and possible overheating.
  4. Install the water inlet housing cover with a new gasket. Install the two hold-down bolts and torque to 43 inch lbs. (4.9 Nm). Do not overtighten these bolts!
  5. Refill the cooling system with coolant.
  6. Start the engine. During the warm up period, observe the temperature gauge for normal behavior. Also during this period, check the water inlet housing area for any sign of leakage. Remember to check for leaks under both cold and hot conditions. Fig. 1: Always observe the positioning of the thermostat in the housing before removing it 85993075.jpg
    Fig. 2: The thermostat should be installed with the jiggle valve upwards 85993076.gif
Aug 11, 2010 | 1991 Toyota Tercel
I cannot find the thermostat on my 1992 Prism. All information has led me to believe I nee to remove the small rubber hose leading from the raiator to the engine. I have disconnected the two bolts and tube...
All Models
See Figures 1 and 2
The thermostat and its built-in by-pass valve is installed on the inlet side of the water pump. Its purpose is to prevent overheating of the coolant by controlling the flow into the engine from the radiator. During warm up, the thermostat remains closed so that the coolant within the engine heats quickly and aids the warming up process.
WARNING A thermostat with an internal by-pass should never be removed as a countermeasure to overheating. Removing the thermostat actually makes the problem worse because more coolant bypasses the radiator, thereby reducing cooling even more.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the water inlet housing and remove the thermostat. Carefully observe the positioning of the thermostat within the housing.
0900c15280047d7b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Thermostat assembly. Prizm shown, Nova similar
  1. Install the new thermostat in the housing, making sure it is in correctly. It is possible to install it backwards. Additionally, make certain that the air bleed valve aligns with the protrusion on the water inlet housing. Failure to observe this placement can result in poor air bleeding and possible overheating.
0900c15280047d7c.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Correct placement of the air bleed valve during thermostat replacement
  1. Install the water inlet housing cover with a new gasket. Install the 2 hold down bolts and tighten them to 20 ft. lbs. Do not overtighten these bolts!
  2. Refill the cooling system with coolant.
  3. Start the engine. During the warm up period, observe the temperature gauge for normal behavior. Also during this period, check the water inlet housing area for any sign of leakage. Remember to check for leaks under both cold and hot conditions.
Aug 29, 2009 | 1992 Geo Prizm
Won't turn off completely, gets warm, won't charge correctly unless hooked to a computer.
Gerrypw - just get a new phon.
TIP DRILL - take the phone to a mobile service center and have them service or replace your charger port.
May 30, 2007 | Motorola Mobility RAZR V3
Samsung Blackjack SGH-I607 Smartphone Logo
149 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
