FixYa.com
Tags:
IBM MicroPortable IL1210 Multimedia Projector
No projection (by 2 users)
posted by melone on Mar 10, 2008
I hear the motor running and have just replaced the lamp, but I'm not getting any projection or light from the new lamp.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 07, 2008
same problem
Best Solution
posted on Apr 14, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you open the front slider, this projector has a small safety switch on the upper-left side (front view). This switch fails often, so try to maintain pushed this switch with a screwdriver (be careful not to touch metallic part in the screwdriver!) and check if lamp goes on. If it works, then close the front slider again until the slider pushes the switch.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
SCART Video Control box
Help! My husband disconnected... Answer This...
Screen is turning blue
My screen is turning blue so I... Answer This...
HELP ME!
We just bought a used... Answer This...
HP VP6210 won´t turn on at...
Hi, my HP VP6210 Projector... Answer This...
Color Red does not Display
The color red displays as... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
