Question about ASUS L38CWB Notebook
Carlos Hello it(he,she) wanted to know if there exists the possibility that I am obtained by the driver of the card of video of one computer ASUS L3800 that I have problems with the video and not eh it could find. If this one inside his(her,your) possibilities of making it come to me for the Hotmail. Oh for another sure and easy place for you ? Thank you anticipadaza, Carlos Hern?ndez says goodbye.
  • ASUS Master
  • 19,396 Answers
Here is download page with drivers for Asus l3800
regards
Posted on Mar 10, 2008
Driver win vista
Is this card part of a computer system? If so, can you go to the manufacturers site and download a driver? If you obtained the card separately you can search google for the term:
HP Asus 5188-6032 TV FM Card Driver "windows vista"
but it's always best to obtain a driver from the manufacturer.
I suspect you obtained this card separately, as neither HP or ASUS seem to support this card and possibly abandoned them because they are analog and not digital rendering them somewhat useless in the USA.
Nov 12, 2013 | HP Asus 5188-6032 TV FM Card & Antenna...
EAX300SE-X/TD/128M Windows 7 driver!?
A very common problem, sadly there is no solution expect the maker of the card to issue a driver for the older card to operate on the newer 7/10 system. Bottom line they want you to buy the new card
May 27, 2012 | ASUS Eax300se-Xtd 128m RADEON X300se Pci...
Is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
Hello plz tell me > supporting
Your mb uses VIA chipset. Here is the ASUS page. Looks like some drivers are here.
http://www.asus.com/product.aspx?P_ID=IQoVElAYUAC4aAz3
Possible secondary source for video.
http://www.via.com.tw/en/support/drivers.jsp
Here is the ASUS page for the product.
Mar 01, 2011 | Computers & Internet
On button flashes yellow but wont turn on
unplug the power cable for 10secs. press the power button while its unplug to remove all the electricity in the cpu. connect the power cable and then press the button. if you hear a beeping sound when you turn on the cpu, you have a problem with the motherboard. if no beeping sound, check the 4 diagnostics lights at the back of the cpu, advtrbl5.jpgMemory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer.
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance
advtrbl6.jpgA possible expansion card failure has occurred.
  1. Determine if a conflict exists by removing a card (not the video card) and then restarting the computer.
  2. If the problem persists, reinstall the card that you removed, remove a different card, and then restart the computer.
  3. Repeat this process for each card. If the computer starts normally, troubleshoot the last card removed from the computer for resource conflicts (see "Resolving Software and Hardware Incompatibilities" in the Owner's Manual).
  4. If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
advtrbl7.jpgA possible video card failure has occurred
  • If the computer has a video card, remove the card and reinstall it, and restart the computer.
  • If the problem still exists, install a video card that you know works and restart the computer.
  • If the problem persists or the computer has integrated video, see "Contacting Dell" in your Owner's Manual.
advtrb16.jpgOther failure has occurred
  • Ensure that the cables are properly connected from the hard drive, CD drive, and DVD drive to the system board.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
Feb 05, 2011 | Dell Dimension 4600 PC Desktop
I can't seem to be able to import two videos I took with my Olympus SP-600UZ to my computer. Ultimately, I want to be able to edit them and post them on YouTube. Is This possible?
I do not know how you tried to unload your videos,if you tried with special cable of your camera sometimes such errors are inevitable.
therefore,the best way to unload the pictures / videos please try to obtain / buy a USB multi memory card reader (it is about 5,00-8,00 USD ) and take your memory card out of camera ,plug into card reader,USB to computer ,here it is ,your pictures and videos are there ( to be seen as external Hard disc on your PC)
After loading them into PC you can work/edit on these videos but you need a special video editing software.You camera CD may have it.Good luck
Regards.
Oct 06, 2010 | Olympus SP600UZ Digital Camera
I want to download a suitable driver for my unknown graphics card
You need to know what graphics card is in it. I think it is either a ati or geforce. go to asus website. look for support and find the drivers for it click on this website . http://support.asus.com/download/download.aspx
Good luck
May 26, 2009 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Video controller problem PLEASE HELP !!!
Hi bullterrier0,
The Asus P4S8X-MX uses an onboard video controller, (SiS Real 256E graphics card).
There is an order of sequences that must be followed when adding another video card on to the motherboard. If these are not followed your new card will not function correctly. Shut down the system. Unplug the power cord from the PC. Open your case.
Please remove any graphics cards you may have added into the system, (For now). Once removed leave your case open & plug the power cord back into the PC. Press the start button. Start pressing the Delete key every two seconds as the PC starts up.
The bios main menu will load. Instruction on how to move about within the bios is listed at the bottom of the menu. You will need the P4S8X-MX manual. (If you no longer have the manual you can download it from Asus by clicking on this link:
http://support.asus.com.tw/download/download.aspx?modelname=P4S8X-MX&SLanguage=en-us
Click the plus sign next to; Manual. Find the English manual.
Create a folder on you're desktop & name it Manual. Download the manual. Save the manual into the folder. The manual will need Adobe pdf reader to be viewed. If you do not have Adobe you can download it for free from this link:
http://www.adobe.com/products/reader/
Once into the bios go to the title Advanced, page 2-17 in your manual or page 59 in Adobe pdf viewer. Open Chipset sub-menu.
Than find, Primary Graphics Adapter page 2-21 in manual, pg 63 in Adobe.
If the TV turner card is an AGP set this to [AGP] & set AGP Fast Write Control to [Enabled].
If you are using a PCI TV tuner card set this to [PCI]. Save the bios & exit. The PC will auto restart. Press & hold the power on button until the PC shuts off. Unplug the power cord from the PC. Re-insert you're AGP TV video card. Double check all internal connectors for good connecting before closing the case. Plug in the PC's power cord & start the system. Once windows has finished loading install the TV video cards driver software.
If you installed software drivers for the P4S8X-MX other than driver software provided by Asus please uninstall that software through Add/Remove programs. (If at all possible).
Since you want to use a TV video card you can not use the onboard graphics card at the same time. This is why windows was restarting. Windows did not know which card to load. Once the onboard card has been disabled by telling the bios to load the AGP, (Assuming you're TV card is an AGP card) windows should run fine. There is always the possibility I interpreted your trouble incorrectly. If this is the case, please let me know & I'll adjust my answer to fit the issue.
Good luck bullterrier0!
Mike
Aug 12, 2008 | ASUS P4S8X-MX Motherboard
ASUS L3500 Keyboard
you remove that using screw driver and be careful to remove the casing be sure the lack is open from the case...or you just get a manual and follow the step to open the casing.....
Dec 10, 2007 | ASUS L3 L3562 Notebook
ASUS L38CWB Notebook Logo
138 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
