Question about Zenith B25A24Z 25" TV
TV - no audio
We have a Zenith model B25A24Z made in April 1999 but has spent most of it's life in storage. We just hooked it up and the picture is fine, but no sound. I've tried unplugging it while on and replugging it 5 minutes later, as suggested as a reset. No luck. I have some experience in electronic repair, but do not have a circuit diagram for this unit. Any suggestions greatly appreciated. We tried to hook up an old VCR to our Zenith B25A24Z tv. In the process we lost all audio even after we returned the set to its original setup. Any suggestions?
  • 2,323 Answers
We lost the chat communication.
check this LINK to download your schematic diagram. Make sure you get all the 7 parts before you can open it.
You will need winrar and acrobat reading 6.0 or newer to view the schematic.
Good Luck.
Posted on Mar 10, 2008
No audio on order from amazon prime
lg tv 32 inc model /// 32lc56-zc i have a problem with the audio can you help my please
Mar 08, 2014 | Zenith B25A24Z 25" TV
The picture freezes and the sound is lost. Until the picture returns and the sound returns,this happens every couple of seconds.
If you actually have the Zenith model TV (B25A24Z), the trouble is not in your set. This model has only an analog tuner, and what it sounds like you are describing is digital pixellation. This is what happens with a digital-to-analog converter box when it gets a weak signal, with rain fade or heavy snow on a satellite dish antenna, or when a digital cable system has some signal problems. The converter equipment locks the last complete frame (or breaks up into blocks and freezes) and the sound is muted.
You'll need to look for the cause of your trouble in whatever is feeding the TV. If you have a digital converter box for off-the-air broadcasts, make sure you have a good antenna and all the connections are tight. If you have satellite TV service or digital cable service, you might need to contact your service provider for help in troubleshooting and fixing the trouble.
Dec 19, 2010 | Zenith B25A24Z 25" TV
The picture freezes and there is no sound until the picture stops freezing. this happens every couple of minutes.
First of all, you certainly have three bad capacitors in this TV. CX3416 is a 25 volt 100mf cap that is bad. Cx 3218 is a 160 volt 2.2 mf cap that is bad and finally C3460 is a 25 volt 220 mf cap. The C3460 is the culprit that is stopping the feed to the audio out put IC. This cap is near the audio IC. It is attached to a large heat sink. Resolder the pins on this IC as well. And after replacing the capacitors, be sure to inspect all solder grounds and resolder as necessary. Hope this helps. Thanks for asking and show a few hands of support.
Can someone take a picture of the original video settings on their Zenith B25A24Z 25'' TV because my screen is all messed up and doesnt get much better when i play with settings.
If this TV is a 25"...then this is an older set. Is the picture dim and the colors dim, will the tint not correct the color scheme? Zenith picture tubes, as a rule, for this model go bad...sorry but this is true!
Dec 10, 2009 | Televison & Video
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
TV - no audio
TV wirked fine for years, but when we moved it to a new house 100 miles away the sound was gone even the cable supplied picture is great. Cable company couldn't recover the sound either.
Mar 04, 2008 | Zenith B25A24Z 25" TV
Zenith tv no pic
You have a picture when you're watching a DVD, but none when you're watching regular cable? Does the audio appear to be okay?? Are you sure you've switched the inputs on the TV back to main???
Let me know..
Bill
Dec 08, 2007 | Zenith B25A24Z 25" TV
Horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Nov 27, 2007 | Zenith B25A24Z 25" TV
Zenith tv
due to shifting your yoke coil might have turned. if you are not tech person get it done by tech. good luck.
Oct 06, 2007 | Zenith B25A24Z 25" TV
No sound on TV
hello my zenith tv has a picture but no sound can youe help me.
Aug 15, 2007 | Zenith B25A24Z 25" TV
Zenith B25A24Z 25" TV Logo
160 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
