If there is still standing water in the tub you can use a wet dry shop vac. attach it to the end of the drain hose and remove all the water.
once the water is removed check the drain pump for any thing that maybe stuck in it to stop the impellar wheel from turning.make sure to check the hose that comes from the bottom of the tub to the drain pump
if there is nothing found then you may need to replace the drain pump. rare occasions the main board needs to be replaced
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
dirty water?
dirty water?
