Blown fuse every time i put in a new fuse it blows, my fuse keeps blowing on my 1996 RCA Big screen tv?
  • 3 Answers
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Posted on Mar 10, 2008
Blowing fuse on tv
hi there's dead short in the power supply somewhere could be a number of components usually diodes or transistors cause this fault
hope it helps
regards
shaun
Jan 04, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
Rca hd52w59 hd tv blown .5 fuse, keeps blowing, screen looks like 3d when this happens
If your fuse keeps blowing you have a shorted parts, if you have a multimeter and know how to use it you can check parts around power supply like diodes, IC's, regulator, and also check the horizontal output or you can call your nearest tech around your area to help you out. if you need more information about tv troubleshooting tips, try this site.
www.my.electronicshelponline.com
hope this help.
Apr 11, 2010 | RCA HD52W59 HDTV Projection Television
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
RCA big screen tv
you got high voltage going somewhere that can be cuased by a blown fuse these rca big screen tv's have up 6 fuses one of them may be blow that needs replacing
Jul 03, 2008 | Televison & Video
No power no sound
oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Feb 05, 2008 | RCA HD52W58 52" TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
Televison & Video Logo
585 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
