Question about Crosley CW6000 Front Load Washer
Will not agitate
It sounds like it is working but it is not agitating
  • sanndy Mar 20, 2008
    it is just barely agitating. Making the sounds, moves slowly in a circle, but its not pulling the clothes down.
  • Anonymous Jan 20, 2009
    kenmore 80 series - does not agitate, rinse or spin. water will drain. sounds like it is working
  • 4 Answers
Motor belt cut Please check .
Posted on Mar 10, 2008
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
How do I remove the agitator from LG top Load washer
the agitator is held by a bolt with a 7/16 drive nut located inside the middle of agitator from the top downward? however by ur description sounds like maybe u have bad bearing in the hub? the cam dogs in the agitator dont usually make any noise especially when bad they just dont allow the agitator to move or catch the groves to agitate. The grinding could also be coming from something stuck inside the tub or on its outside and thus is hitting the wall lining and makes a screeching scraping sound, Ive seen this several times, a bra wire, or loose coin or key, etc
Sep 28, 2014 | Washing Machines
Top load washer agitator is not working properly--not getting full agitation.
Most whirlpool washers have a dual action agitator. It sounds like the top part is not working. There are 4 small gears that turn that part of the agitator . Remove the top cap of agitator and replace the dog ears, most appliance parts stores stock them and they are pretty inexpensive. Thanks
Jul 08, 2011 | Whirlpool Washing Machines
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
Agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
May 13, 2009 | Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
The agitator works intermittently
Replace the agitator dogs (4 small white/beige plastic parts) inside the agitator, they are worn.
The part number is 80040.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator not working properly
if the agitator barely moves, sounds as if yo have a bad set of agitator dogs, part number 80040. if you removeth agitaotr,(7/16 screw) down the center ofthe shaft. yo can removeth efabric softener dispensor by hitting with the palm of hand. after removing the agitator, it can be split in half to reveal hte "agitator dogs" easy repair problalbby about $20 and 30 min tops
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator problem
Check and see if it spins freely in both directions. If it does, this means that your "dogs" are worn out in the top agitator. This is an easy fix. You just get the new ones (usually 10$ or less), pull the top cover off the agitator, then pull the center cap off inside of the agitator. Then you just remove the center bolt and pull the whole top agitator off. You will see the 4 plastic dogs right on the top of the agitator.
Oct 16, 2008 | Washing Machines
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
Crosley CW6000 Front Load Washer Logo
89 people viewed this question
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
