Hi, - To connect karbonn k406 mobile to your pc to your computer you need only a data cable which you brought with the mobile (Accessories).
- But to connect your karbonn k406 mobile to your pc for browsing (internet) you need a pc suite (software). - If the pc suite for your mobile is not available on internet to download you have to contact the nearest service center to avail the pc suite for free.
- After installing the pc suite in your computer connect the mobile using the data cable which you got with the mobile when purchased (if not you have to buy one). Please rate if this solution was helpful, thanks!
you can use mobile to connect to the internet. Initially your network provider must support internet connection facilities . Then your mobile must contain inbuilt modem and driver for that modem. The G five mobile does not have a inbuilt modem so it is not possible to connect to internet
but i sugest to you connect t with bluetooth....just buy cheap bluetooth device and paired your mobile with pc then make a dialup conection for your pc
try to call to your "provider" Provider - it is company which gives facilities of Internet.
You can do this by as minimum five times way: 1) through modem 2) through LAN card 3) through WIRELESS LAN card 4) through mobile (cell) phone and USB connection 5) through mobile (cell) phone and BLUETOOTH connection
Also you may combine or switch suitable ways of the work on your discretion. Good Luck. Find " Internet provider"
for accesing net in pc via mobile .... activate ur gprs settings in ur mobile.... now get a nokia pc suite cd and install the necessary drivers and connect the mobile to the pc ...... the console page will have the connect to internet option , please click on that for using internet. if u don't have the nokia pc suite cd download it from net.while installing the drivers please mention ur phone type as nokia 6020.
Its not true that one cannot access internet on pc via htc p3400i. Right now I am using the same to post this message. The problem is there is not much help available on the internet. Hence i have decided to post the solution.
Here are the steps.I took to enable vodafone mobile connect on my htc p3400.
1) You will first have to enable gprs on you mobile by calling helpline.
2) Go to start->settings->connections(tab)->connections
Click advanced tab. Then cilck select networks. You will see 2 drop downs. In first drop down select vodafone mobile connect and in second drop down select my isp.
This is all that you need to configure on the phone.
Now connect the data cable to the pc and then connect the phone to the cable. you will be asked two questions. Select USB for one and select vodafone mobile connect for the second.
Now go to start->programs->internet sharing and say connect. You are now ready to surf internet on the pc. just fire your fav browser and check it out.
Thanks,
Nilesh Gadkari
my handset is nokia N70. i use airtel gprs on mobile. i connect mobile with nokia pc suit on computer. but internet not start on pc. please send me setting for pc
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
