FixYa.com
Tags:
Vivitar 283 Flash
Vivatar 283 and Nikon D70s (by 2 users)
posted by EDKELL on Mar 10, 2008
Can I use my old 283 with the new digital Nikon d70 without fear of a short in the electronics?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Rekusu, posted on Jul 31, 2008
I have been Googling the Vivitar 283/285 voltage issue for use with a Nikon D300.
I am confused about measuring the discharge voltage.
Using a dial volt meter, set in the 10v DC range, when the flash discharges, the needle only deflects briefly to about 3 or 4v. Would this be correct and therefore it is OK to use my 285 with the D300.
Many thanks for your advice,
Rex
Solution #1
posted on May 09, 2008
Not Rated (0)
FlashyBits
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 21, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I use my 283 gun with a Fuji s9500 digital camera without problems.
Can you Help with these Flashes problems?
Flashes
SB-20 flash wont turn on
Left batteries too long in my... Answer This...
Flashes
Novatron 240 Flash Kit
I have an old Novatron 240... Answer This...
Vivitar 283 Flash
Manuak for vivitar 283 Flash
Looking for a copy of this ,... Answer This...
Vivitar 283 Flash
broken shoe foot and lost...
where and how can i get this... Answer This...
Vivitar 283 Flash
50 inch viera panasonic
have taken my viera to italy,... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
