I am responding to you
What you can do is in IE hit view>source, then notepad should open up (or your text editor) scroll down to your key and edit it and save it
SM
Att answer machine #1717
How to retrieve messages away from home ?
Posted on Apr 28, 2008
How to Edit XML Files?
From the File menu, select New, and then select Project. Select the code language of your choice, select Empty Project, and click OK. The XML Editor finds the schemas you add to this project and uses them for validation and IntelliSense in anyXML, schema, or XSLT files that you edit while this project is open.
Oct 18, 2016 | Computers & Internet
Tip
How to jump to a registry key directly ?
When you start Regedit, it automatically opens the last key that was viewed. (Registry Editor in Windows XP saves the last viewed registry key in a separate location). If you wish to jump to a particular registry key directly without navigating the paths manually, you may use any of these methods / tools.
Option 1 Using a VBScript: Copy these lines to a Notepad document as save as registry.vbs
'Launches Registry Editor with the chosen branch open automatically
'Author : Ramesh Srinivasan
'Website: http://windowsxp.mvps.org
Set WshShell = CreateObject("WScript.Shell")
Dim MyKey
MyKey = Inputbox("Type the Registry path")
MyKey = "My Computer\" & MyKey
WshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Applets\Regedit\Lastkey",MyKey,"REG_SZ"
WshShell.Run "regedit", 1,True
Set WshShell = Nothing
Double-click Registry.vbs and then type the full registry path which you want to open. [ Example: HKEY_CLASSES_ROOT\.MP3 ]
Limitation: The above method does not help if Regedit is already open.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
CAP LIGHT DOES NOT COME ON
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How can i store formula in ti-90 titanium?
There are a number of ways you can store a formula.
The first is to store is in y Vars. Just input your single variable equation into the graphing screen, then trace to find the value.
If you want to store something more complicated than that, or just store some plain text, creating a non functional program is then next best way.
To create the program: Hit the apps key and then scroll down to 7:Program Editor then hit enter Create a new program (name it whatever you want).
Type in your text and when you are done hit 2nd then quit
It should display the text your previously typed in.
To display the program: Hit the apps key and then scroll down to 7:Program Editor then hit enter Thenscroll to 2: open, hit enter. Select your program then press enter.
Feb 24, 2011 | Texas Instruments TI-89 Calculator
SEARCH GOOGLE USING E-SPEAKING
These commands are built-in. You do not have to add or program them.
Working with Applications
Say... Open Word
Open Excel
Open Email
Open Powerpoint
Open Internet
Open Notepad
Close Application
Close Window
Close Document
Scroll Down
Scroll Up
Start Word
Start Excel
Start Email
Start Powerpoint
Start Internet
Start Notepad
Minimize
Maximize
Scroll Left
Scroll Right
Browsing the Web
Browse the web using the following commands: Open Internet
Google Website
Yahoo Website
Altavista Website
MSN Website
eBay Website
e-Speaking Website
Go Back
Go Forward
Refresh
Dialog Commands
Sometimes a program will simply ask you for a yes or no answer to an alert box or dialog. Yes
No
Cancel
Affirmative
System Commands
You can control when e-Speaking is "listening" to you using these voice commands. Standby
Resume
Stop Listening
Begin Listening
Hello
Computer
Listen to Me
Add a New Command
Add Mouse Click
Moving the Mouse
The Mouse Movement option has to be checked on the Mouse menu. Mouse Left
Mouse Right
Mouse Down
Mouse Up
Faster
Slower
Stop
Mouse Clock One
Mouse Clock Two
Mouse Clock Three
Mouse Clock Four
Mouse Clock Five
Mouse Clock Six
Mouse Clock Seven
Mouse Clock Eight
Mouse Clock Nine
Mouse Clock Ten
Mouse Clock Eleven
Mouse Clock Twelve
Slide Left
Slide Right
Slide Down
Slide Up
Mouse Buttons
Select
Double Click
Right Click
Properties
Drag Item
Drag File
Drag Object
Release Item
Release File
Release Object
Mouse Jump To
Mouse One - Top of Window
Mouse Two
Mouse Three
Mouse Four - Middle of Window
Mouse Five
Mouse Six
Mouse Seven - Bottom of Window
Mouse Alpha - Left of Window
Mouse Beta
Mouse Charlie
Mouse Delta - Middle of Window
Mouse Echo
Mouse Foxtrot
Mouse Golf - Right of Window
Editing Commands
Doing some word processing? These commands may help perform common Windows functions. Select All
Edit Copy
Edit Paste
Edit Undo
Edit Delete
Edit Find
Delete Line
Find
Search and Replace
Moving the Text Cursor
These commands may help navigate documents. Left Arrow
Left One
Left Two
Down Arrow
Down One
Down Two
Right Arrow
Right One
Right Two
Up Arrow
Up One
Up Two
Page Up
Page Down
Beginning of Line
End of Line
Beginning of Document
End of Document
Simulating Keys
Enter Key
Home Key
End Key
Spacebar
Escape Key
Delete Key
Backspace Key
Tab Key
Dictation
Start Dictation
Stop Dictation
Standby
Resume
Train Word
Show Commands
Dictation - Editing
Delete that Phrase
Delete that Text
Delete Last Phrase
Delete Last Text
Strike that Phrase
Delete Last Word
Edit Copy
Edit Paste
New Line (inserts a line)
Next Line (inserts a line)
New Paragraph (inserts 2 lines)
Next Paragraph (inserts 2 lines)
Select All
Delete Key
Backspace Key
Reading Commands
Read All Text
Read Selected Text
Stop Reading
Pause Reading
Resume Reading
Skip Ahead
Skip Back
Read Faster
Read Slower
Phonetic Alphabet
You must really like using voice if you are into the Phonetic Alphabet. Alpha
Bravo
Charlie
Delta
Echo
Foxtrot
Golf
Hotel
India
Juliet
Kilo
Lima
Mike
November
Oscar
Papa
Quebec
Romeo
Sierra
Tango
Uniform
Victor
Whiskey
Xray
Yankee
Zulu
Feb 05, 2011 | e-Speaking
Change text size in IE
To change the text size on a Web page, open IE
•Select the Page menu-> View
•Point to Text Size.
•Select your choice of Largest, Larger, Medium(default), Smaller, Smallest text sizes.
0r
• ->Zoom ->(Zoom in & Out)
or
Hold down the [CTRL] key as you scroll your mouse wheel up and down. As you do the text will either increase or decrease depending on which way your move the wheel.
Hope it helps.
Oct 26, 2010 | Microsoft Internet Explorer 8
Iam unable to view instant messagas from my yahoo messenger.
1. Exit Yahoo! Messenger by right-clicking the tray icon and selecting Exit.
2. Before you edit the registry, you are advised to make a backup:
a. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
b. Type regedit and click OK. This opens the "Registry Editor."
c. On the "File" menu, click Export.
d. In the "Export range" panel, click All, then save your registry as Backup.
3. In the "Registry Editor," browse down to following location in the registry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\
4. You should only see a list of numbers under Zones. If you see an unrecognizable character before zone 0, delete that particular key.
5. Close the Registry Editor.
6. Open up Yahoo! Messenger and try to send messages again.
Jul 19, 2010 | Yahoo Messenger
Windows notepad is in computer code, cannot read text--vista when i open up hp help line it comes out in code no html or plain text
notepad is not meant for viewing formatted html or other help files other than TXT files.
You may have accidentally changed an association.
to change it back for html lets say then right click on the file then use "open with" then "select program from list"
when the list opens scroll down and click "internet explorer" and tick the "always use this application" box
Aug 11, 2009 | HP Computers & Internet
I want to edit docs in version 8, when save the pdf as text opens in notepad and formatting is trashed is there any way we can set that to open in word with formatting intact
You will lose a lot of document format if you open a pdf file in word. I suggest that you use an appropriate pdf editor, like Adobe Acrobat full. It has all the features that you need to edit, create pdf files, also export doc files to pdf
Mar 05, 2008 | Computers & Internet
Serial number of windows 98
the s>n for windows 98 is :
KYFCR-98MMC-CJVKM-9H33T-VVGDB
or
win98: m34Gj-9b4R3-ck3bw-m7mk3-9wvGy
2-
win98: PDXVM-3QGHD-7PF4D-28WQR-3WBW3
3-
win98 :pdxvm-3qghd-7pf4d-28wqr-3wbw3
4-
win98 :KVBHH-2VG4T-D2JRQ-TXVM7-QXWTT
and you welcom
bay
nevo
Nov 06, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
Alun Cox
David Payne
David Payne
