Monitor problem i have a Philips 190c 19"LCD monitor and until recently i've had no problems with it. Now when i power it up it comes on for a second and then switches off can any one help?????
    Problem Solver:
  • 8 Answers
Try and unplug the monitor from rest and check it in another room with fresh power supply...if still it turns off than its time u need to change the monitor and if it stays well on than there is some issue with ur cpu ie motherboard or the graphics card....
Posted on Mar 14, 2008
I VE A SAMSUNG LCD TV/MONITOR SNYCMASTER 932 19
can you see that a capicitor 820/10v is pluked ? replace it.
Feb 21, 2010 | Samsung SyncMaster 932B LCD Monitor
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Keeps switching on and off.
sonia7palmer, If 190C still does same when reconnected to a KNOWN GOOD pc with the WIN-desktop showing, you WILL do one of the following: 1. Trade in for new wide screen LCD unit! The Technician in the back of the store will (with a little luck) put $3 to $7 in parts into your monitor so he will have a spare at home to use. 2. Do a cash+old unit swap with Philips for a REFURBISHED unit. $50 to $100 cost if they even support your unit yet. 3 Check with local TV/monitor repair shop to repair your unit. $50 to $90. 4. View repair and or disassembly videos(8-12minutes) on YOUTUBE of LCD monitors being worked on and repaired for low cost DO-IT-YOURSELF'ERS" and also check out other sites like www.ccl-la.com/badcaps.htm , and www.lcdparts.net
to see if that interests you. If this info helps please rate this response on fixya. 12fixlouie Bye for now.
Nov 01, 2009 | Philips 190CW8FB LCD Monitor
Computer screen goes to no picture after about 1
time for A new monitor or your video card is faulty
Oct 19, 2009 | Philips 190B6CB/27 19" LCD
Philips 19s lcd monitor
you have to replace the capacitor in the high voltage board inside your lcd if you know how to open it
Nov 03, 2008 | Philips 190S7FS (Silver) 19 inch LCD...
Philips monitor
Sounds like you have a bad inverter. You will need to open up the monitor to get to the screen to access the inverter board and replace it. If you are handy you can do the job yourself but if not then you will need to take it in to a computer repair shop to have it serviced. Depending on how old this monitor is, the cost of the repair maybe prohibitive.
Mar 12, 2017 | Philips 190CW8FB LCD Monitor
I have a Philips 19" Lcd When i swithced it on everything was fine until about 5 seconds later the screen went black. I have found that if i switch the monitor off and then on it works ok until...
A 19" Philips LCD prefers a setting of 1440X900 if you are too far off this it will turn itself off.
Right click on the desktop, go to settings and set it to 1440X900 and then go to advanced and make sure the refresh rate is set to 60 Hertz. Shining a flashlight on the screen will help you see.
There other thing that might be causing this is the setting on the monitor itself. Press the Menu button on the LCD and adjust the brightness and contrast.
If all else fails, contact Philips. This is a premium brand and it comes witha 4 year warranty.
Oct 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Black Screen
Edwards,
What you mean by replaced the fuse? Are you replaced the capacitors on the AC Adapter. If so, Then it's not the only problems. The main problems is the backlight inverter needed to be replaced. Go check out my website @ www.3rd-rocks.com
and click on LCD Parts. If you have any questions just email to to me @ cjt@3rd-rocks.com Have a nice...Happy July 4th!
CJ
Jul 04, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
