Question about Jenn-Air JGR8875QDS Gas Kitchen Range
Model JGR8855ADS Jenn Air Gas Oven
F9 Code won't clear and door won't unlock
    Genius:
  • 1,665 Answers
Hi have a nice day!
Posted on Mar 10, 2008
  • 3 more comments
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 10, 2008
    The following parts at link below are used with Model Number JGR8855ADS
    http://www.appliancepartsworldwide.com/S...
    I m looking for a service manual ..
    Generic:
    Fault Code Interpretation Components To Check
    F-1 Communication error between touch pad and ERC (clock)
    Replace the touch pad or clock.
    F-2 Oven temperature sensed by electronic control Replace the clock/relay board
    F-3 Open oven sensor or harness. Replace the oven sensor
    F-4 Shorted oven sensor or harness Replace the oven sensor
    F-5 Power to element relay disabled in cook mode Replace the clock/relay board
    F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
    F-8 Shorted meat probe Replace the probe jack.
    F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
    F-C or F-0 Communication error between boards Replace the relay board
    Go to this link. insert mode No (JGR8855ADS), select Brand (Jenn Air), Appliance Type : Range/Stove/Oven and Part type:Door & handle components
    SEE Item #703637
    sorry I forgot the link. Is HERE
    Items cost $ 52,55 in stock.
    At Part Type, select (Door & Handle Components)
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Oven was off...woke up to oven beeping and the F9 code came up & door is now locked. What is F9??
This waht F9 mean
F9 Door latch Check door latch components.
You will need to replace door latch
Oct 01, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Have a jenn-air gas range with a f9 code come on with oven is use. What is this code.
Hi There
I have found this code for you and hope this helps you.Let me know how it goes.
F9 Door lock safety circuit on power relay board sensed Replace power relay boardThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
Feb 18, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Oct 25, 2009 | Jenn-Air JGR8855BDS Gas Kitchen Range
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
What is an F9 error and how do I get my oven door open
We solved this by holding the light/door switch in, hit the clean button, then press stop/clear for 3 seconds.
Dec 25, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
379 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
