Question about Kitchen Ranges
I have a 3 year old Kenmore range. There are openings at the top of the oven door. While cleaning, some soapy water went into one of these openings and left water dribble marks. How do I get inside the door to erase these unsightly marks?
    Novelist:
  • 131 Answers
You'll have to remove and disassemble the door to clean the back side of the glass.
Open the door slightly. It should hold itself slightly ajar. Then lift the door straight up and off the hinges. Lay the door on a floor, table or flat countertop with a towel or rug protecting the door. The screws holding the door together will be on the bottom, top, and sides. Sometimes there are screws on the inside, holding the door handle and outer glass. Take care to notice how it's assembled, as getting it back together is sometimes tricky. By the way, it's best to lift the door by the sides, not by the handle!
Posted on Mar 10, 2008
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
HELLO,
Please carefully apply the below instruction to clean up your range
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
    HELLO,
    HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    Failure Codes
    The F9 code indicates there is a problem with the door lock.
    Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
    Try canceling the clean cycle without putting the control into clean.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^&^%$#
    Apr 19, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
    Can the things that sit on top of the gas burners be put in the electric oven and be clean with the oven cleaning setting?
    No. The self clean temperature (about 900°F) will burn the paint off, and may deform the grates. They are cast, but could still be damaged. Spray them with oven cleaner, then soak them in hot soapy water, brush them with a good stiff scrub brush and rinse thoroughly.
    Jan 07, 2010 | Kenmore Kitchen Ranges
    Kenmore mirowave # 72162643200 handle is broken
    I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
    As for the door... I very CAREFULLY used super glue/ gel and it did the job!
    Mar 27, 2009 | Kenmore 62643 Microwave Oven
    Self cleaning oven
    It may have sliders inside the oven door .Open the door and look at each side for metal slide plates that when pulled upward they seal off the glass for self cleaning. If you dont have those ,I just wasted alot of typing.
    Jun 07, 2008 | Kenmore Kitchen Ranges
    Gas range
    I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
    Can you help ? Thanks, Tom
    Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
    Kenmore Elite Range door locked error message
    Hold down the number three button until the LOC message disappears and then the door will open.
    Dec 23, 2007 | Kitchen Ranges
    Kitchen Ranges Logo
    150 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
