Question about Microsoft Xbox Console
Help my xbox is now saying evolution x instead of main menu,can't save a game why is this how do we get our main screen back
    Problem Solver:
  • 8 Answers
Evolution X should have a menu item saying "Dashboard" or similar. There's your original main screen.
Posted on Mar 17, 2008
How to Mod Using Modio?
    1)SB Flash drive for Xbox
    2)Choose game save you want to mod, and move it to USB
    3)Take USB out of Xbox and plug into computer
    4)Open up Modio 5
    5)Check button that says gamesaves
    6)In bottom right of window, there's a search bar, where you can type the name of the game
    7)Find a file you want to download and double click it
    8)Click button in bottom right of new window
    9)Exit out of windows and main menu for Modio
    10)Click Open save from device from main menu
    11) Leave window open, you will need it later
    12)Click on open and save on main menu
    13)Find file you downloaded earlier, and double click it
    14)Put save file from device on right side, put other file on left side
    15)Left side window bars delete them all
    16)Copy numbers from right side window, and paste them in corresponding bars on left side window
    17)Close out right side window
    18)In bottom right of remaining menu, click button that says rehash and resign
    19)Find button on open window that says Save to device
    20)Take out USB and plug into Xbox
    21)Move modded file onto Xbox
Oct 20, 2016 | Video Game Consoles & Games
How to Mod an Xbox?
Use Modio 5
    4)Open up Modio 5
RAGE fails at locating my HDD
take it off give it a clean if there is any dust or anything around it and put it back in and make sure it is connected properly. some times it hasnt connected properly and thats why you get the message
Jul 27, 2012 | Bethesda Xbox 360 - Rage
My xbox Your Shape 2011 game isnt saving any progress any more
This is acually a common problem for that game. The only suggestion I would take is to reload the game saves on your XBOX. To do this, you go to Settings-System-Storage-All Devices-Games and Apps-You Shape (press Y on the game instead of A)-Delete. Then, go back to the main menu and load up the game. It may take longer to load due to the original save file being deleted, but it will then record your save file. If you followed those suggestions and it still doesn't save, you may want to contact XBOX for troubleshooting ideas or Ubisoft.
Hope that helps. Good luck!!!
Jun 22, 2012 | Ubi Soft Your Shape: Fitness Evolved for...
When I try to load my saved Fable II games on my xbox 360 and hit 'Continue', it says "verifying saved game" but just continues to run without finding the saved content.
Either your savegame got deleted or corrupted. If it still shows up in the main menu, I would suggest copying it to a flash drive and trying to start a new game. If you can make a new game then your savegame is corrupt and you cannot use it anymore. If it will not allow you to make a new save then chances are your Fable 2 disk has been scratched and can no longer be used.
Mar 21, 2011 | Microsoft Fable 2 for Xbox 360
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Any game i play disk arcade or demos xbox freezes
Try the following:
  1. Hold disc by the edges without touching the surface with your fingers. Clean the disc with a soft cloth, lightly wiping from the center outwards. Do not use solvents or chemicals to clean the disc. Examine the disc for any visible signs of damage.
  2. Verify whether the Xbox console clock is set correctly.
    • Turn on the Xbox console without a disc in the drive.
    • Press the directional pad up or down to select Main Menu, and then press A.
    • Press the directional pad up or down to select Settings, and then press A.
    • Press the directional pad up or down to select Clock, and then press A.
    You can see the date and time from this screen. Correct the date and time as neccessary.
  3. Try to play the game again. If this does not work, you can try to clear the game cache on the Xbox hard disk. If you have a Xbox Memory Unit available, copy the game cache for this game from the Xbox hard disk to a memory unit:
    1. Insert a memory unit into a controller connected to your Xbox console.
    2. Open the disc tray and remove any disc, if present.
    3. Close the disc tray and re-start your Xbox console.
    4. Select Memory from the main Xbox Dashboard, and then press the A button.
    5. Select Xbox Hard Disk, and then press the A button.
    6. Locate and select the game you want to back up in the list of games.
    7. Select the appropriate save game icon. The Save game icons are located to the right of the game icon. Each save game is identified with a name, date, time, and size.
    8. Press the A button to display the Copy/Delete menu for the save game.
      Note: If Copy is not available, you have not chosen a save game file.
    9. Select Save, and then press the A button.
    10. Press the A button again to save to the appropriate memory unit.
    11. As soon as the copy is complete, press the B button to return to the list of save games.
    12. Repeat these steps as needed to back up your other saved games for this game.
    If you do not have a memory unit, deleting the game cache removes your progress in the game, high scores, and other information. To find the game cache, follow these steps:
    1. Open the disc tray and remove the any disk, if present.
    2. Close the disc tray and re-start your Xbox console.
    3. Select the Memory option from the Dashboard.
    4. Select the Xbox Hard Disk.
    5. Locate and select the game in the list of games.
  4. Select the large game icon to the left of the list and press the A button.
  5. Press the Abutton again to delete the game cache file.
    Note: Delete should be the only available option. If Copy is available, you have chosen a game save file and not the game cache file. Press the B button to return to the list, and then select the leftmost icon.
  6. Select Yes to permanently delete the game cache, and then press the A button.
  7. Confirm that the icon is no longer listed, and then re-start your Xbox console.
  8. Insert the game disc, and then either load your latest saved game from the memory unit, or play the game from the beginning.
Sep 19, 2009 | Microsoft Xbox 360 Console
Deleting previously stored saved games/profiles on lego batman ds
When on the main menu trey clicking on new game instead of load game and then if a screen appears saying are you sure the you have deleted the previous game save
May 19, 2009 | Warner Bros. Interactive Lego Batman for...
Xbox menu
reload your bios and that should help your box. Also try a quick tap to the power or eject button. This might reset your box manually.
Apr 05, 2008 | Microsoft Xbox Console
GAME NOT PLAYING
There could now be a problem with your HD, check 'memory' in the system blades, if your games are still there then this would indicate some sort of communication problem between the HD and console however, if you find your games are not there, I would say that Microsoft have somehow cleared your HD. If your game saves are not there it would be a good idea to contact Microsoft again and explain the new situation. I'm sorry if this is not much help to but I am unsure myself as to what could actually be causing the problem. Please rate if it is at all helpful, thanks.
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
99 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
