Tip & How-To about Daewoo Nubira
How to Remove Tail Lights on a Daewoo nubira Car?
The tail light consists of the brake lights, reverse lights, parking lights and turn indicator lights. 1)Tail lights at the back of your car. 2)Tail lights are on each back corner of the car. 3)There is plastic lens on above the tail lights in car. 4) Remove the screws on lens cover. 5) Remove the bulb after lens is removed. 6)The access panel will be on the inside of the trunk in the same position as the tail lights. 7)Open the trunk to access panel for the tail lights. 8) The bulb is screwed. 9) turn it counter clockwise to loosen and remove the bulb. 10) Reinsert the new bulb in the same procedure of how to removed. This will help.thanks.
Cars & Trucks Logo
how do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
