Question about Gateway 2520915 Keyboard
Enter Key My enter key has a little plastic piece that's missing on the underside which has made it difficult to press. Where can I find a new enter Key?
  • 73 Answers
Hi asongforyou,
the enter key might be getting at ur nearest shop of any computer just tell him that ur keys had been broken or plastic piece has been missing he will give u or just go to the repairing shop of computer
regards
shailesh
Posted on Mar 11, 2008
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
My facebook, firefox. youtube all are not loading correctly. the script is on the left side of page with nothing in middle. Has little links and blocks all crowded to gether and everything is messed up....
RESET THE machine, follow this steps and fix it. God bless you
      • 3
      • 4
      • 2
    Oct 24, 2013 | Exercise & Fitness
    After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
    rests the treadmills, follow this steps and fix it. God bless you
    replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
      • 1
      • 3
      • 4
      • 2
    Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
    Fitstride t920 treadmill faults
    Reset the machine follow this steps and fix it. God bless you
    1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    · 2
    · 3
    Oct 07, 2013 | Exercise & Fitness
    Chrome OS is damaged or missing
    To install the Google Chromium operating system (OS) on your computer, instead of booting it from an image or using an official Google Chrome OS netbook, you must compile the Chromium source. Compiling the Chromium source is a complex task that might be difficult for novice computer users. The first stage of the task requires preparing the hard drive for a new installation by formatting it. All commands entered to the kernel are Linux commands because Google Chromium is based on Linux.
    Insert the Chromium installation disc in your computer. Restart the computer. When prompted, press any key to enter the boot disc. A kernel shell will flash while waiting for a command. Type "fdisk /dev/hda" and press "Enter." Type "d" and press "Enter." Type "1" and press "Enter" again to delete the initial partition. Type "n" and then "p." Type "1" and press "Enter." This creates a new partition. Press "1" and press "Enter," then press "Enter" again. Type "mkfs.ext3 /dev/sdb1" and press "Enter" to create your new file system for the drive. Type "mkdir /disk1" and press "Enter." Type "mont /dev/sdb1 /disk" and press "Enter," then "df-H" and press "Enter." This partitions and formats your hard drive, which now is ready to work using the Chromium operating system. http://www.chromium.org/chromium-os/developer-guide
    Jan 28, 2013 | Samsung Chromebook Series 3 XE303C12
    Enter bios password
    If you want to add the BIOS password:
    1. Restart the computer.
    2. At the SONY screen, press the F2 key.
    3. In the Setup Utility window, press the RIGHT ARROW to select Security .
    4. On the Security menu, press the DOWN ARROW key to select Set Machine Password .
    5. Press the ENTER key.
    6. At the prompt, in the Enter New Password field, enter the desired password.
    7. Press the ENTER key.
    8. In the Confirm New Password field, retype the same password.
    9. Press the ENTER key.
    10. At the Setup Notice prompt, press the ENTER key. NOTE: To set a user password, repeat steps 4-10, selecting the Set User Password option.
    11. Press the F10 key.
    12. In the Setup Configuration window, press the ENTER key.
    13. Press the RIGHT ARROW to select Exit .
    14. Press the DOWN ARROW key to select Exit Setup .
    15. At the Exit Setup prompt, press the ENTER key.
    If you want to remove the forgotten BIOS password:
    Please call 888-476-6972 and speak directly to a Sony® support representative for further assistance. A resolution for this issue is available, but for security purposes, this resolution can only be provided by a support representative.
    Jun 12, 2010 | Sony VAIO VGN-N385E/W Notebook
    I.removed.the.laptops.spacebar.and.i.cannot.get.it.back.in.there.seems. to.be.4.little.pieces.of.white.plastic.and.two.thin.metal.wires.on.the....
    The two pieces of metal should snap into small slots on either side. Then you press it straight down so the plastic piece locks into the button on the membrane on the keyboard assembly. Good Luck
    Jul 28, 2009 | Acer TravelMate 5720-6462 Notebook
    IntelLoader is missing
    I think your computer displays a message that ntldr is missing.
    Use the following steps to replace these files. Insert the Windows XP bootable CD into the optical (CD or DVD) drive and restart the computer.
    1. When prompted to press any key to boot from the CD , press any key on the keyboard.
    2. Once in the Welcome to Setup screen, press the R key to repair Windows.
    3. Press the 1 key and then press Enter .
    4. Type the Administrator password at the prompt.
    5. Copy the NTLDR and NTDETECT.COM files to the root directory using the following steps:
      1. Type copy d:\i386\ntldr c:\ (assumes the optical (CD or DVD) drive is d) and then press the Enter key.
      2. Press the Y key at the Overwrite ntldr? prompt.
      3. Type d:\i386\ntdetect.com c:\ and then press the Enter key.
      4. Press the Y key at the Overwrite ntldr? prompt.
    6. Once both files have been successfully copied, remove the CD from the optical (CD or DVD) drive and type exit at the prompt and then press the Enter key. The computer will reboot.
    Nov 24, 2008 | Microsoft Windows XP Professional With...
    Printing blank page
    Ok here are a few things to try first, if they fail to work, reply here with the results and we can work from there..
    1.) remove the cartridge and blot it on tissue paper to ensure it has ink..
    2.) go to the printer preferences
    Start / All Programs / Printers and Faxes,,
    Right Clik on the printer and click properties
    YOUR PRINTER SETTINGS MAY VERY FROM HERE BUT ITS BASICALLY THE SAME PRINCIPAL AND YOU WILL FIND THE FEATURES JUST PROBERALLY IN ANOTHER LOCATION
    Click Printing Preferences then maintenance
    Click Cartridge settings
    Ensure its set to print from both black and color cartridge..
    Just find the settings and make sure its set to print from both cartridges..
    Let me know how that plays off and we can work from there...
    but that should work..
    Feb 22, 2008 | Brother DCP-110C All-In-One InkJet Printer
    Gateway 2520915 Keyboard Logo
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
