Question about Belkin MiniScroller Mouse
How do i install a mouse on windows98 without original startyup disks
How do i install a mouse on windows98 without original startup disks
  • 655 Answers
For installing a generic mouse you need not to use any startup disk.
1. Make shutdown your pc.
2. Connect your mouse.
3. Boot your pc.
A message will be display by window that new hardware found, (if your mouse hardware is differ from previous mouse), and window will install the required driver for your mouse.
Thanks
Iqbal
Posted on Mar 10, 2008
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
I bought a mac book from a co worker and it did not ever ask me for an admin password, and i did not create one. Then something happened to my battery and i had to replace it, now when i start it it askes...
The only thing you can do is to reinstall the operating system from disk.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Apple Computers & Internet
Component details
ZENITH NOTEBOOK, Z-NOTE 425Ln+, CPU 80486DX 25MHZ, 8MB RAM, 1.44MB FLOPPY DISK DRIVE, 200 MB HARD DISK DRIVE, 9 PIN SERIAL PORT, 25 PIN PRINTER PORT, PS/2 MOUSE PORT, VGA MONOCHROME VIDEO LCD, EXTERNAL VGA CONNECTOR, AC ADAPTER, WEIGHT 8 LBS,
You can install Windows 95, I'm not sure about Windows98
Aug 25, 2009 | Computers & Internet
Bad disk
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
System recovery
Solution :
Request Backup Disks and Manually Reinstall :
If other methods for reinstalling your operating system have failed, the only option is to reinstall from the installation media.
Request Backup Disk by clicking the link below :
https://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
After Seaching a lot on google finally i got the link ,which willb be very helpfull to you
link :
If you need any further assistance just reply me at fixya or contact me at my email id
johny_inmexico@yahoo.co.in
Was this solution helpful? Show your Appreciation by rating it:...............THANKS
May 08, 2008 | Dell Latitude D600 Notebook
How to install mouse model #AMW25
can i know which version of operating system you are actually using...
if it is higher than windows98 ..the hardwares are automatically detected.....no need of installing
else you got to install the driver..
Mar 08, 2008 | Computers & Internet
Upgrading Computer
All you have to do is re-boot from the xp disk.When promted,press any key to boot from the disk.The installation program will then start.Just follow the prompts from there!
Feb 21, 2008 | Computers & Internet
Fellowes Keyboard and optical mouse
keyboard and mouse usually plug n play no need to install software..
Feb 13, 2008 | Fellowes Cordless Optical Keyboard/Mouse...
Wireless mouse
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Oct 06, 2007 | Logitech Cordless Optical Mouse for...
Trouble installing driver in Windows 98 without original install disks
I would look for the whole driver package from http://www.driverguide.com If you have the files downloaded why are they on the floppy? You can point the installation to any location, including the hard drive of the laptop. Driver guide does require a (free) membership to download, but it's a great site.
Jun 08, 2007 | Belkin MiniScroller Mouse
Belkin MiniScroller Mouse Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
