Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
Ipod just pauses
I have a 20gb ipod, it will just pause and then I'm unable to do anything. Last time it did this I put it on the charger and after being charged it worked again for maybe 15 songs now it's done it again and it's fully charged.
  • Raphono May 06, 2008
    i have the same problem, whenever i try to play my ipod it won't respod, i think there's something wrong about the wheel, and also even if i resets it and it still not work...pls..i need help....
  • Anonymous Jul 19, 2008
    none
  • 502 Answers
This can be caused by the audio jack, if it doesn't sit tight anymore, the headphone becomes disconnected for small periods of time causing the iPod to detect the headphone as unplugged, hence it will pause. If you're out of warranty you can send it to a third party iPod Repair Service.
Posted on Jun 05, 2009
When i turn on my apple 3rd gen 20gb ipod it comes up with the apple sign and after a few seconds it comes up with and ipod with a sad face and www.apple.com/support/ipod underneath. What do i do??
The first thing is to connect your iPod to the computer it is paired with. When iTunes recognizes it, click the button returning it to factory settings. This will delete all data from your iPod, but should repair any software problems.
If iTunes is having a problem recognizing the iPod, than place it into Disk Mode: (From http://www.apple.com/support/ipod/earlier/)
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Dec 05, 2010 | Apple 20gb Ipod Mp3 Player With Click...
My ipod 80gb is saying apple.com/support/ipod
Try resetting it. Sometimes that's all it needs.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Feb 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
My computer will not recognize it.
I would start with attempting to reset the iPod to get it to connect to the computer. If that does not work, attempt to force it into disc mode. And if all else fails try another USB port on your computer or a friends computer. If it does not work try a different cable with your iPod to ensure that it is not just a cable connection :) Below is a step by step on resetting an iPod as well as disc mode just in case you need the information :)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
May 18, 2009 | Apple 20gb Ipod Mp3 Player With Click...
I plugged my ipod 3rd generation 20 gb into my mac to delete some songs so I could add new ones...the screen came up in iTunes and it said it was disconnected improperly even though it was still hooked...
I would force the iPod into disc mode before attempting to connect the iPod to restore it. Below is a step by step on forcing an iPod into disc mode just in case you need the information :)
Apr 30, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod 20gb click not recognized by windows
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time. :) Let me know if this does not resolve your connection issues
Apr 29, 2009 | Apple 20gb Ipod Mp3 Player With Click...
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Ipod 20GB screen stuc on picture of charger and socket???
do a reset. i believe it is hold center and play at same time for 10 seconds or it is the center and menu buttons at same time for 10 seconds to restart it. I hope this helps. This will not erase anything it is like restarting your computer. Good luck
Feb 19, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Apple iPod Nano is stuck on pause
Mary
Switch the hold on and then off again and then hold the menu and select button at the same time until you see the apple logo.
This should reset the Ipod.
Dec 30, 2008 | Apple iPod nano 3rd Generation
My iPod won't go to sleep
try holding down pause and then move the hold switch sraight after. hope i was a help xx
Apr 05, 2008 | Apple iPod nano
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
96 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
