Question about Samsung SPP-2020 Thermal Photo Printer
Paper won't feed on my Samsung SPP-2020
The rollers look like they're trying to pick the paper up but it just wont 'catch' it and then the printer times out and the standby button flashes red. This has happened ever since I got new photo paper for it but it is exactly the same paper!
  • kim Mulholland Jun 17, 2008
    I have the exact same problem. But, when I replaced the cartridge, my printer did not do anything different.
    Still not printing.
  • camel_toe71 May 07, 2009
    I have the exact same problem. It's Samsung paper I bought, but it won't catch in the rollers!! It's so anoying!!!!!
A friend advised me to clean the rollers with nail varnish remover or any acetate on a cotton bud, and it worked perfectly straight away/ good luck
Posted on May 25, 2012
I had the same problem and replaced the ink cartridge and hey presto ! it worked
Posted on Mar 18, 2008
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
Paper feed won't pick up paper. tried to put single paper in but paper jam light goes on but no paper located. we think we need new rollers for the paper feed but not sure where to get them in...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
May 12, 2011 | Lexmark E232 Laser Printer
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Feb 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Rollers unable to pick up the new paper I received recently. Had a few sheets of old paper left and working fine with these. I saw there was a similar question posted by someone else with same problem.
clean your paper receiver roller,
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 23, 2009 | Samsung SPP-2020 Thermal Photo Printer
The rollers in my samsung spp-2020 are sticking
On most printers there's a "thing" near the rollers that grabs the paper. It's usually a flat piece of plastic with some kind of stuff on it that grips the paper. It's actually on the out bound side of the printer. You can re-glue the pad by super glue if the part isn't available.
Jun 21, 2009 | Samsung SPP-2020 Thermal Photo Printer
Samsung 2020 photo printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2020
You need to get the exact photo paper for this model.
The ones that comes with the flaps on each ends.
Without the flaps, the printer won't print.
Aug 05, 2008 | Samsung SPP-2020 Thermal Photo Printer
Paper not feeding in the machine and get a paper jam error Printer rollers do not grab the paper to load into the printer. The rollers turn, put the paper is not loaded.
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Jun 18, 2008 | Samsung SPP-2020 Thermal Photo Printer
Rafique:- Samsung SPP 2040 paper problem.
If its new, You may contact nearest service center.
Mar 27, 2008 | Samsung SPP-2040 Thermal Photo Printer
Samsung spp2040 printer
The roller of the paper pick up is rotating or no. If rotating and not taking rollers need a cleaning try this else change the roller.
Mar 24, 2008 | Samsung SPP-2040 Thermal Photo Printer
Samsung SPP-2020 Thermal Photo Printer Logo
1,225 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
