Question about Toshiba Satellite A65-S126 Notebook
Fail to load files during text mode setup
Hai,
my laptop is quite old and the OS clashed. am trying to load windows but it cannot load some Xp files during text mode setup so it terminates installation. when another RAM was used, it loaded the files but stil could not continue installation, it says my BIOS is not ACPI compliant and brings a blue screen. I tried different HDD but nothing was solved
    Scholar:
  • 151 Answers
Maybe its a software problem, have you tried putting in a bootable XP installation CD? After the bios boot and it asks you to boot to CD, press R for repair, it will try to repair your OS, and if it is an OS problem ,then it will boot once again... If not you can try formatting your HDD and reinstalling windows...
Posted on Mar 10, 2008
I have a Plustek OpticFilm 7600i SE film scanner. Every time I try and load-up the setup disc, the set up install starts and then comes up with this error message: An error (-500 : 0x8004ace8) has...
It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
Good Luck!
Mar 10, 2011 | Plustek OpticFilm 7200 Film Scanner
When my laptop is turned on, it shows, We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped...
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
XP REPAIR INSTALL 1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order. 2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R". 4. Accept the License Agreement and Windows will search for existing Windows installations. 5. Select the XP installation you want to repair from the list and press R to start the repair. 6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. 7. You will need to apply Windows updates after this procedure.
Sep 21, 2010 | Dell Inspiron 1545 Notebook
Problem loading OS on Gateway MT6451, Main File Error
This looks like a corrupted file in the boot section or a virus attack. the only solution is to reinstall the OS. there is no hardware error, if you had any hardware error the display will not be working fine. reinstall the Windows OS.
Please encourage us if this tip was helpful to you.
Apr 02, 2010 | Gateway MT6451 Notebook
I am trying to install windows xp home edition on my compaq presario 1260, and everything i have read states that this is possible. my issue is that when it gets to the "set-up is starting windows" it...
The following items can cause Setup to stop responding while the "Setup is starting Windows" message is displayed:
  • An incorrect mass-storage device (such as a SCSI or IDE controller) driver is being loaded, or the driver was not written for Windows and is not compatible. Contact the device's manufacturer or download the latest driver for the mass-storage device. For additional information, click the article number below to view the article in the Microsoft Knowledge Base: 216406 Specifying Third-Party Disk Controller Driver During Setup
  • There is a device connected to your mass-storage device that is preventing Windows from being installed. Remove any devices (such as scanners, tape drives, removable drives, and so on) from the mass-storage device controller. If the computer is IDE-based, verify that you have the master and slave designations set properly. If the mass-storage controller is SCSI-based, verify that the termination and bus speed is set properly.
  • The computer does not have the latest BIOS revision. Contact the computer's manufacturer or check the manufacturer's Web site. Many manufacturers have updated their BIOS revisions to properly support Advanced Configuration and Power Interface (ACPI).
  • An ACPI Hardware Abstraction Layer (HAL) is being used during Setup. Force the use of a non-ACPI HAL during Setup. For additional information about this procedure, click the article number below to view the article in the Microsoft Knowledge Base: 216251 How to Specify a Specific or Third-Party HAL During Setup
For additional information, click the article numbers below to view the articles in the Microsoft Knowledge Base: 224826 Troubleshooting Text-Mode Setup Problems on ACPI Computers 220845 Adding Third-Party or Updated Driver During Windows 2000 Setup
You may have to load you SATA drivers first? OR choose another HAL, press F6 during setup.Setup ACPI also.
Feb 08, 2010 | Compaq Presario 1260 Notebook
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Assist with an Operating System start issue? PC is a Gateway GT5228
the following will re-install windows without destroying your stuff but you must follow it exactly !!!!!!!
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" height="21" alt="To setup Windows XP now and Repair Install , press ENTER." src="http://www.michaelstevenstech.com/note.gif" width="15" border="0" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  7. good luck beergut707
Oct 09, 2008 | Computers & Internet
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
OS load failure.
The bluescreen saying about the ACPI, I had the same problem at work with a older computer. Next time you get the bluescreen read everything it says.
It tells you to press a button, I'm not sure thats why I'm telling you to read the bluescreen (windows 2000 or xp) it was f5 or f8.
You press f5 or f8 I think it was f5 since f6 is to load custom drivers.
So you press f5 when it asks you to press f6 This disables the ACPI subsystem in the setup and you should be able to install windows 2000 without any more problems. If its not f5 read the bluescreen thats where I got it!
Good luck, keep me posted and tell me if theres anything else.
Feb 23, 2008 | Toshiba Satellite A65-S1065 Notebook
Switching off at os setup
I had the same problem, when I took it down to Tiger Direct it appeared that I had a corrupted hard drive. I bought a 60GB for about 20 bux since then I haven't had any other issues.
Feb 11, 2008 | Toshiba Satellite A75-S211 Notebook
Driver error upon boot
You have a corrupt OS, assuming you have XP, you should do a repair installation. Don't worry, none of your files or settings or installed programs will be deleted. You may have to reinstall some old device drivers though. * Insert the XP CD and boot to it * When you see " To setup Windows XP now, press ENTER", go ahead and press ENTER * You will now see an option to repair Windows by pressing "R". Do not select this option - it will only take you to the Recovery Console which is not what we want to do. Instead, choose to continue the installation * When you see the license agreement, press F8 to agree * On the next screen make sure your current XP installation is selected and then press "R" to repair XP * At this point XP will begin to install on top of itself, replacing damaged, missing or altered system files. Follow the instructions on the remaining screens to complete the Repair Install. It will look very much like a normal (new) OS installation. If all goes well your repaired XP installation will remain intact, keeping your personalized settings and installed programs as they originally were.
Aug 08, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite A65-S126 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
