Acer Aspire M1641-U1521A  PC Desktop Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hey plz any1 help me how to changing in bios from Sata to IDE to installing XP , [email protected] i wish some1 help thanx for u all
electronic & computer repair& servicre
Level 3:
  • Acer Master 12,061 Answers
  • Posted on Mar 18, 2010
Acer Master
Level 3:
Answers
12061
Questions
0
Helped
4008187
Points
36390
There is no setting in BIOS for that? You simply MUST get a XP SP2 Install disk, and NOT an "older" version, that requires a SATA driver at install time. Chexk out link below news.softpedia.com/.../Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml -
How to change sata to ata in bios
If you want to install Windows XP or configure a RAID array, you may need to change the SATA type in BIOS. here I will introduce some method of SATA settings in BIOS. SATA HDD(hard disk) has been more porpular because of the hight transferring speed and simple installation. If you want to Install a Windows XP in SATA hard disk. we offen need a floppy disk to save the additional driver of SATA/RAID. but the floppy isn't too easy to find. So we can do another method, modify the SATA type to compatible IDE or ATA mode, etc.
Notes: If your computer has installed some operating systems. Changing SATA types may corrupt your systems or need to be repaired again. But when can I change the SATA type?
1. You are prepairing install a new operating systems, for commonly Windows XP. If Windows 7/Vista will be installed. you need nothing changed in BIOS unless the setting has been modified.
2. Or you want to install a RAID.
I will introduce how to install Windows XP at SATA HDD(hard disk) in the coming chapters, here we need to know how to change the SATA type in BIOS. At first we need to access BIOS, Here is my desktop BIOS, we can find the BIOS is from AWARD software.
201003290718324672.jpgIn my BIOS, the harddisk settings are in the line of integrated peripherals, different BIOS or different OEM menufactures may have different promise. you can try the Advanced BIOS features setting or Integrated peripherals, or system configuration, etc.
Locale to Integrated Peripherals and press enter, you may find the SATA configuration.
201004010308121905.jpgthe above screenshot is the SATA configuration position. There are two items about SATA controller, Onchip SATA controller and Onchip SATA Type, Notes: There may be one or more configurations about SATA, we only need to change the SATA Type. you should not close the SATA controller if you don't know what's will be happened.
Navagete to the Onchip SATA Type and press ENTER, we can find these selections: Native IDE, AHCI, RAID. If you want to install Windows XP, you may need to change to Native IDE(some called ATA) mode, when you finished installation, you can refresh your SATA drivers in Windows XP and change the SATA type to AHCI mode in BIOS again.
If you want to configure a raid array. set to RAID similarity. When finished settings, you should press enter to accept it, and save to CMOS before restart your computer. In my BIOS, I need to exit to the BIOS main menu at first and save it.
when the new status has been saved, you can press CTRL+ALT+DEL to restart your computer, some OEM PCs may need to click the EXIT or Save to CMOS and Exit, the computer will be restart automatically.
Another example screenshot is my DELL notebook BIOS. DELL BIOS is not the same as the desktop BIOS, we can find the SATA operation behind the System Configuration. there are only three selections (Disabled, ATA, AHCI). If you want to install Windows XP, here need to be changed as ATA mode.
201004010308185104.jpg Notes: If you want to install operating systems, you may need to change the boot orderto boot from your CD/DVD drive.
tip
HP 6730s bios password
Hey guys plz any1 can help me ?
i got bios password in laptop hp 6730s plz can some1 tell me how to remove password from bios ?
i have remove it battry from motherboard and didnt work ?
wish some1 answer me thank for all ya
on Mar 25, 2010 • Computers & Internet
tip
INSTALLING WINDOWS XP ON A SATA HARD DRIVE
SATA HARD DRIVE ? XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP.
The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
If enabling the SATA in the BIOS does not allow the computer to boot up with SATA hard drive then change the BIOS back to what it was previously.
on Mar 14, 2010 • Computers & Internet
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
1helpful
How to change bios setting on GA-F2A55M-DS2 motherboard to install XP
The BIOS should not prevent you from installing Windows XP.
If your hard disk is a SATA hard drive then -
1helpful
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
2answers
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
1helpful
2answers
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
