Question about Bauknecht 24 in. GSF8984 Free-standing Dishwasher
Bauknecht GSF 4862 error-light (like a waterdrop with 2 lines below it)
I have a Bauknecht GSF 4862, when I start my dishwater after a few minutes the third light (like a waterdrop with 2 lines below it) turns on and it stops! Anyboday can help me out? Regards Frank / Barcelona, Spain
  • pirdom Oct 30, 2008
    All'accensione della mia lavastoviglie Bauknecht gsf 4872 si accende il led dell'acqua stop e dopo varie pressioni al pulsante di start spunta il codice F2. Potete chiarirmi quale รจ il problema e come risolverlo. Grazie
  • s_galien Mar 16, 2009
    I have a Bauknecht GSF 4872 where the error light burns (like a waterdrop with 2 lines below it).
    Any solutions
2 Suggested Answers
  • 641 Answers
SOURCE: What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Posted on Jul 26, 2007
Bauknecht gsf 4481
The timer is not advancing to the next cycle. Replace the timer.
Mar 13, 2014 | Bauknecht Dishwashers
My Bauknecht GSF 6550 dishwasher is stuck with error F4. Whar does it mean ? What can I do?
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. The error indication can be a short in the circuit, check the heater circuit and the pump motor.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Sep 03, 2011 | Bauknecht 24 in. GSF8984 Free-standing...
Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Apr 14, 2009 | Siemens Dishwashers
Bauknecht GF7199 F7 light has come on
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Mar 06, 2009 | Bauknecht Dishwashers
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
May 04, 2008 | Dishwashers
GSF 3152 S
Fehler gefunden und repariert, vielen Dank und Gruss !
Apr 02, 2008 | Bauknecht 24 in. GSF8984 Free-standing...
What does F7 Means?
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bauknecht 24 in. GSF8984 Free-standing Dishwasher Logo
999 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Carmen Mikulic
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
