Question about Canon CanoScan LiDE 600F Flatbed Scanner
LiDE 600DF - Unable to scan
LiDE 600F having problems with scanning to PDF file. Unable to scan. Mak sure there is enough space on the target disk.. I have over 30G available.. What do I so?
  • 9 more comments
  • lobo1 Mar 12, 2008
    Unable to scan. Check if target disk has enough capacity
  • Anonymous Mar 24, 2008
    same issue here, for no reason
  • Gary_Jackson Apr 09, 2008
    I have a Canon LiDE 600F scanner. If I run OmniPage SE4.0, when it comes time to scan a document, the whole program simply disappears!
  • tryintoo Apr 16, 2008
    I also am unable to scan into pdf files with CanoScan 8600F. Unable to scan. Make sure there is enough space on the target disk. I have 40 GB available.
    Any suggestions would be appreciated.
  • Baechtold Martin Apr 17, 2008
    I have
    I have 60 Giga free and it says not enough space
  • trying4 Aug 17, 2008
    I have the same problem. Mine has been working perfectly until recently. The error message sudenly started appearing. I have tried re-installing the software to no avail. I have half of my 250G HDD free and yet I get the message to "make sure there is enough space on your target disk".
    The only thing I can think of is that I did a direct scan to an memory stick recently, just before this trouble started. However, my settings direct the scan to the C-drive. I tried with a memory stick again without any success.
    I am using Windows XP as I had always. So the suggestion that Vista may be the cause is not valid.
    Unhappy.
  • Birl Smith Jan 16, 2009
    I have 50G of free space. Tried shorter path, file name and different hard drive. None worked. Help.
  • cecjohn May 04, 2009
    I have the same problem: "unable to scan. Make sure there is enough space on the target disk."
    I have tried reloading the driver, restoring the defaults, and also shortening the path to the target folder to c/temp.
    Nothing works! Help! This scanner used to work fine!
  • kahedin May 14, 2009
    Having used Canoscan Toolbox 5.0 with Vista during the last 2 years, I now suddenly recieve the message "Make sure there is enough space on the target disk" Message also appears when using 'Copy to printer' 173 GB available diskspace on target disk.
  • tryintoo May 11, 2010
    to trying4 or dkeds66,
    where is the configuration file for the canon toolbox 5?
    Thanks
I think I might have solved my own problem, at least for the time being. If my theory is correct, then it might be a permanent solution.
I had been goint through the "CanoScan Toolbox 5" configuration line by line to see if anything would suggest a solution when I noticed that the "Folder for where temporary files are stored" had an enormously long path of C:\Documents and Settings\username\Application Data\Canon\TB50\...... By the time the temporary filename is added to the end, it may have exceeded the permissible length the system can handle. So I changed it to C:\Temp and it all started to work for me.
Worth a try for my fellow sufferers.
Trying4
Posted on Aug 23, 2008
I had the same problem with a CanoScan LiDE70. In Canoscan Toolbox under settings, I just restored the system defaults. Everything works fine after that. Had the same problem on two different machines and restoring defaults waorked on both.
Posted on Mar 24, 2009
This problem happens anytime I don't use the scanner for a while. Perhaps updates from other programs create these problems, I don't know.
Anyway, I had the same problem, and tried the earlier suggestions: Changed the destination folder to C/temp.
That didn't work. Then I went to Settings in the CanoScanToolbox, and found that the Button Settings were not correct, with Photo-1 being set at Copy function, or some such change. I corrected Photo-1 to be for Photo, and now it seems to work.
Posted on May 05, 2009
I did the same as the other chap and reduced the temp folder path - it all started working again
Posted on Jan 28, 2009
The C:\Temp solution worked for me, too. But it didn't last. I believe that a registry scan/delete was the cause. I redid the C:\Temp, so I'll watch this next time I run the reg. scan.
By the way, can't Canon provide a permanent fix for this somehow? They're usually very good at customer service.
Posted on Jun 22, 2009
When i had the same problem, I used the C:\temp suggestion and it worked for a while. When the problem recurred, I select the default location under the "settings" button which worked for a while. Then back to using C:\temp which again worked for a while, etc. etc. etc. So, just keep on cycling mate!
Posted on Jan 15, 2010
    Scholar:
  • 111 Answers
Gary Jackson,
Are you using Windows Vista?
If so, you most likely need the upgrade.
http://www.nuance.com/vista/omnipage/canon/
Posted on May 09, 2008
Thanks so much to the dude with the c:\temp solution!! I can't begin to tally the time I've spent trying to figure out this problem.
Posted on Apr 27, 2009
Can not scan. Get message "Unable to scan. Make sure there is enough space on target disk". Changed default temporary disk location, have plenty of disk space.
Had this before and after a day of playing about with cleaning out the windows temp folders, I simply uninstalled all the driver and toolbox software, downloaded the latest version from Canon's site and reinstalled it. After doing a bit of research, found out it was caused by a windows update conflicting with the drivers
Dec 27, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Not enough space on target disc
If you are scanning in color choose JPG option as the file size is small. Delete unwanted files in the target location and create space.
S. Mohan
Dec 04, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan Lide 600F I can't scan bacause I keep getting a message about a target disc????
target disc means hard drive or other disc that the file temporary loads to. its either full or most like write protected. right click on the scanner in control panel or the scanners. select "where" to save to in the popup menus
Oct 09, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
A window appears saying "unable to scan. Be sure there is enough space in the destination disk."
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Sep 28, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Connot make a pdf scan. get a reply thet there not enough space. installed latest drivers. working with xp
Issue: ERROR: Insufficient space on target disk
Solution: Change where temporary files are saved (Toolbox)
Change where temporary files are saved (Toolbox) For an unknown reason, the computer is not allowing temporary data to be written to the general folder chosen by Toolbox at the time of install.
  1. From the CanoScan Toolbox, click the Settings button.
  2. At the bottom you will see a section that states, "Select Folder Where Temporary Files are Saved:".
    Click the Browse button.
  3. Browse to a folder, such as C:\Temp, and then click OK.
  4. Click OK again to exit the Settings window.
  5. Try scanning again.
Sep 13, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Canoscan lide 70
Head for the Canoscan Toolbox and click on "Settings".
Under "select folder where temporary files are saved", click on "browser".
Choose where you want the scanned item to be sent and then click 'OK".
This works for me.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
2,352 people viewed this question
old marine
old marine
