Question about Acer AL2017 20" LCD Monitor
Monitor is Flickering and screen becomes pink
I have an Acer Al2017 20" monitor - bought it last summer.
Lately the screen flickers and everything turns pink tinged, then it goes back to white.
Can someone tell me why this is happening, and should I try to get it fixed?
Thanks
  • mxmama101 Aug 27, 2008
    My 2017 is flickering red/pink as well. Any suggestions?
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes back to white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Posted on Mar 14, 2008
Acer X193HQ Screen Flickering
this means their is some conflicts between the graphics card drivers or the drivers are not installed properly. so re-install the graphics card drivers.
Oct 23, 2009 | Acer AL1916W 19" LCD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Acer al2423W lcd monitor has begun vert-flickering
that happens when the monitor is on the way out i think you looking at new one
Nov 26, 2017 | Acer AL2423W LCD Monitor
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
MY ACER LAPTOP SCREEN TURNS ON BUT THE SCREEN IS BLACK
To determine if you have a video card problem or the LCD screen is at fault.
Connect an external monitor to the video port on the laptop and boot up your laptop, if you get a display on the external monitor then your video card is OK and you have a faulty LCD.
When you power your laptop without an external monitor and have a close look at the LCD screen at and you see a slight image then the fault is with the backlighting panel. This fault could be a faulty inverter or a faulty CCFL backlight lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
The inverter can be easily replaced so can the CCFL lamp (but requires a lot more work)
For info on parts and repair service goto www.lcdparts.net
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
Jan 06, 2009 | Acer X193W LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
