Question about GPS
Dead tomtom910 sorry new to computers too. the back light is dead. the only illumination is the charging light
  • 1 more comment
  • aajlrrecruit Mar 10, 2008
    how do I continue to communicate when you ask another question about my original fault
    I do not know what the light is supposed to do. It is on all the time it is plugged into the charger, it does not flash ,flicker or extinguish, it has been on for about 6 hours now.
  • davidw7867 Aug 25, 2008
    My Magellan Roadmate 700 starts up beautifully, but after a few minutes, the backlight goes out. I can still make out the map, but I have to shine a light on it to read it. Any ideas?
    President:
  • 1,944 Answers
You can continue to post here and I will see the messages.
Posted on Mar 10, 2008
Will not keep the battery charged.
Something is on, check all interior lights and in glove box. Also check the boot light. make sure the radio is off. do the checks by illumination. remove battery cable and if there is a spark when connecting there is still something on.
Feb 25, 2015 | Cars & Trucks
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
Changed radio instramentpanel gages lights went dead
You probably touched a wire wrong and blew the fuse for nighttime illumination, same fuse that lights up the dash. Also, you might've hooked up the vehicle illumination wire wrong in the back of the new radio, causing a short and the fuse blew
Jan 18, 2011 | 1996 Jeep Grand Cherokee
Tomtom910 not holding charge or charge properly
Looks like the battery needs replaced. Go to: http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
This site will give yo step by step how to change the battery. Good luck!!!
Oct 03, 2009 | Tomtom GO 910 GPS Receiver
Tomtom910 won't turn on. I replaced the battery, charged it and now it won't turn on.
Try doing a reset. The reset hole is on the bottom of the TT 910. Use a paperclip to do the reset. Gently push the paperclip into the hole until you feel a click the hold it for 30 seconds. That should do the trick, unless the unit is not actually charging. The green light will come on but not charge because of a bad connection on the motherboard on the negative side.
Jun 20, 2009 | Tomtom GO 910 GPS Receiver
I have a Gateway MX6930. I purchased a new battery because the old one's life had shortened so much. The new one worked fine for a few days but now doesn't work at all. The battery charge light illuminates...
Yes you are right, a defective battery.
It's always recommended that you use manufacturers endorsed hardware because of this fact!!
Return the battery and get a new one. when you get the new battery don't charge it, just use it until its dead and then recharge it. It will then hold 100% charge.
Good luck
Jun 12, 2009 | Gateway 7330GZ Notebook
My toshiba laptop will not turn on...
This could be a few things. It could be a bad power cord not charging the battery or the machine. But it could also be various other things. The cheapest and easiest thing to try is a new power adapter.
May 26, 2009 | Toshiba Satellite A60 Notebook
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
Charging lg kg 220 phone
Almost certainly liquid damage to the lower part of the phone!
Depending on your skills, removing the back cover (the bottom lifts after removing the four screws and then you need to twist and tug the top to get the back off) and clean the bottom 1/4 of the phone using a toothbrush soaked in isopropyl alcohol. Then dry completely with hot air, a hair dryer will suffice.
10 out 10 non-charging KG-220 seem here in the last six months were all fixed using this method!
The classic indication is when plugging the charger into the switch on phone, the handset turns off.
Dec 11, 2007 | LG KG220 Cellular Phone
GPS Logo
88 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
