Question about Lexmark C510 Laser Printer
Constant paper jams.
Usually prints one page then jams.  Quite often, it never even prints, just jams.
  • 21 Answers
In your printer the carrtage is jam fromdust
Posted on Mar 12, 2008
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
It started getting jammed recently quite often and generally happens when the paper tray isn't full. It usually either gets jammed near the tray or in the back.
i take it that you getting mutiple different jams and pretty often correct? these printer use a paper size select pcb when these start to go bad the paper size can be change every time you close the drawer or every other page you print. print your network page and see if it prints as big as the page if its smaller the printer thinks it has smaller paper if the lower black line of the box around this page is missing it thinks it should have longer paper. this board is located behind the metel box the logic board is mounted in. for cheaper prices,instruction and support for your lexmark lasers go to L-tech4u.com write an email if you dont see what you need listed they will have it
Nov 12, 2009 | Lexmark Optra S 1855 Laser Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Continual problem with paper jam
try with other manufacturer's paper, you can try by reinstalling the drivers
if the problem persist then your printer needs to be serviced
May 31, 2008 | HP Photosmart C7280 Printer
Prints a couple of pages - then jams
Well, for now it seems to be fixed - I opened up the paper tray and there is a little part that grabs the paper on the front of the tray - kinda sticky - I just took a paper cutter and put a couple of scratches on it and it is grabbing the paper for now. I do have some of those to use for replacements - but I had just changed it about a month ago and don't think it needed to be changed out again - they usually last quite a while. So, we'll see how long this lasts. We do a lot of printing on this thing and it has been a great printer - maybe we are just wearing it out!
May 20, 2008 | Ricoh CL4000DN Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Paper jam
can u see any part of paper anywhere in paper ,usually it gets stucked on the back side in the fuser assy ,remember dont try to remove any paper with any metalic tool even if u find any peice of paper
Jan 23, 2008 | Samsung ML 2010 Laser Printer
Lexmark C510 Laser Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
