Question about Thermador MBYB Microwave Oven
Thermador MBY microwave
My microwave oven after 2 seconds shuts off and the display says cooling....
The problem is the push-on connector on the UPPER door-latch switch; if the white plastic around this connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blade on the switch before reconnecting as the heat has likely left a burnt coating.
Posted on Jun 07, 2008
Microwave shuts down after 2 seconds
unplug the appliance from the main socket and plug it after sometime
Jun 07, 2013 | Thermador MCES MCEB Convection Microwave...
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Goes to cooling down and shuts down -Thermador MBY
It sounds like the magnetron is overheating. There can be several causes:
- the vents are blocked
- the outside outlet of the air duct is damaged or has an animal nest in it
- the filters need to be cleaned (if grease filters) or replaced if charcoal filters
- the magnetron is failing
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can possibly download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your detailed symptoms.
Dec 12, 2009 | Thermador Microwave Ovens
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door not latching
One of my friend who can fix almost anything is coming once a year to fix all that is broken and not working. It has become a yearly routine. This works out way more cheaper than trying to fix all these "wonderful" appliances myself!
Dec 30, 2008 | Thermador MBYB Microwave Oven
Thermador model CM302UB displays error F34 when microwave is in use for morwe than 2 minutes
There are two main possibilities. The first is that the main circuit boards in the oven are not being properly cooled. The second is that there arere are some components that have become thermo sensitive, and are acting with heat.
Check to make sure that the vent fan is working properly. Check to see if the vent hole in the rear of the oven is clogged with a lot of dust. If there is dust, clean it out.
Jerry G.
May 14, 2008 | Thermador Microwave Ovens
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Jan 22, 2008 | Thermador MBYB Microwave Oven
Thermador MBYB Microwave Oven Logo
572 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
