Question about Vacuums
Panasonic upright vacuum MC-E458
Panasonic upright vacuum will not pick up, although the brush is working fine
  • kevmorris Mar 10, 2008
    Forgot to add, there are no blockages.
  • 833 Answers
Sounds like a problem with the impeller. It is loose or broken. It is attached to the motor shaft.
Posted on Mar 10, 2008
HOW TO CHANGE A BELT ON A MC-V7305
Make sure vacuum is unplugged. Lay. Vacuum upside down and remove Bottom plate. Pull brushroll from nozzle housing, pull metal end caps from brush and remove any hair and debris. Put new belt around motor shaft then around brushroll. Put one hand on each side of belt and pull brushroll to stretch belt far enough to drop brushroll into position. Make sure brush spins freely. Install bottom plate. Make sure brushroll turns freely, if not, make sure bottom plate is not restricting the belt before you turn the vacuum on. Repeat the process in 6 months. You may be surprised to see how much a belt stretches and loses elasticity after it's been on your vacuum for 6 months.
Feb 08, 2015 | Panasonic Vacuums
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
I own a Panasonic ME-C4051.
Check by the brush roll, the inlet may be clogged, also may be time to change the belt, they stretch after a while.
Mar 26, 2008 | Vacuums
Can not find a new brush
You should be able to order thru a repair shop, you will need your model number. Are you talking about the brush roll or an attachment brush?
Jan 05, 2008 | Panasonic MC-V7720 Bagless Upright Vacuum
Change belt
To get to the brush roll, you have to take the bottom part. There is no belt, the brush roll motor is part of the brush roll.
Dec 29, 2007 | Panasonic MC-E583 Bagged Upright Vacuum
Not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Vacuums Logo
101 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
