ZEBRA PRINTER WE HAVE A ZEBRA PRINTER THAT PRINTS LABELS USING TL LATCHFORD SOFTWARE. THIS MORNING THEY WERE PRINTING LABELS AND IN THE MIDDLE OF IT, A WINDOWS TEST PAGE PRINTED. FROM THEN ON, THE PRINTER SEEMS LIKE IT LOST THE FORMATTING OR SOMETHING FOR THE LABELS. THEY ARE ALL PRINTING CUT OFF. THEY HAVE ALREADY POWERE OFF THE PRINTER, RECALIBRATED AND THEY CANNOT PRINT LABELS AT ALL. i AM NOT SURE IF THIS IS A PRINTER PROBLEM OR A TL LATCHFORD SOFTWARE PROBLEM.
  • DOO12 Mar 13, 2008
    We reset the printer and the formatting was ok.
  • Anonymous Feb 23, 2009
    We had that happen on our Zebra printer as well after I had tried sending some ZPL commands to it through notepad. What we did was through the LCD on the front of the printer accessed the setup menu and reset the print width to the correct size.
  • 86 Answers
Try reloading the TL LATCHFORD software
Thank You
Posted on Mar 11, 2008
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
We can't get our Zebra TLP2844 to print on the left matgin. It only prints in the middle of the label, which messes up the barcode. Our IT Dept has the manual and they can't seem to fix it. It was working...
reset the printer to factory defult ( from the driver( download segull driver) www.seagullscientific.com
check if the driver that you using have the correct Length and the With from the labels that you use.
Print a test page (should come with windows logo plus the text in all label. clean the printhead.
Aug 18, 2010 | Zebra LP 2844 Thermal Printer
Good morning, having problems with zebra printer 110xilll Plus. white streak down middle label. V
You can try cleaning the print head with Isopropyl Alcohol, if this doesn't fix it - you printer will require a new Print head
Jan 20, 2010 | Zebra 110Xi III Plus Thermal Printer
Using copaq 7400 laptop for running zebra 90xiIII
Can you explain in complete sentences what you are trying to achieve here?
It sounds like you:
have 90XiIII printer
have a Laptop running Windows 98
either need or have a driver
either need or have a label printing program
want to print labels with sequential numbers.
Go to zebra.com and download the Zebra Designer label creation software package. Read the help files. Install the driver for your printer from this application. Create a label and hit print. the sequential label feature may not be available on the free version.
Jan 18, 2010 | Zebra 90XI II Printer
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Printing every third labels ---> not every one:(
Sounds like the label height is set too high. Go into Printer Preferences in Windows and change the height dimension to match the size of the label you are using.
May 08, 2008 | Zebra S4M Thermal Label Printer
Improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
183 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
