Question about Dell Latitude D600 Notebook
LCD Is there any way to repair the LCD screen for a Dell Latitude D600 PC Notebok, if the screen dim?
1. Plz replace the HT unit.
2. Replace the LAMP of LCD.
Posted on Mar 28, 2008
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
The screen is so dim,it is barely visible
Replace the laptop. Alternatively, replace the LCD for it, the backlight is dead. Quite franly, the former is cheaper.
Dec 28, 2009 | Dell Latitude D600 Notebook
Battery not charging but notebok vorking properly.
Suggest battery is at the end of it's 'Life Cycle'. Replace the battery.
Apr 13, 2009 | Dell Latitude D600 Notebook
Replaced screen computer comes on, but screen stays black.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 22, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 display blacks out, showing just a ghost image
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 21, 2009 | Dell Latitude D600 Notebook
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 LCD is Dim
This sounds like a minor solder crack on your power supply board. i would disassemble and preform a break point test with an voltage needle. This way, you can locate this hairline solder break and re solder this point so the full A.C. current can flow normally.
Feb 17, 2009 | Dell Latitude D600 Notebook
Wanted: replacement display screen - Samsung 14.1"
HI
You can buy from any of these.
http://www.google.com/search?rlz=1C1GGLD_enIN307&aq=f&sourceid=chrome&ie=UTF-8&q=D1002+dell
I have got almost 3.
Shopping results for D1002 dell D1002 - Dell Latitude D600 LCD Screen $149.97 - Renwerx Tech DELL D1002 LATITUDE D600 SXGA+ 14.1 DIS $253.75 - codemicro.com Dell D1002 LCD 14.1" TFT SXGA+ LATITUDE D600 $488.75 - eBay
Do let me know if you need further information. Its pleasure to assist you. And let me also inform you that can call Dell Spare Parts Sales and ask them to get this one for you. You get 90 days of warranty as well.
The part number is D1002 for the monitor.
Thank you
Rakesh
Dell Expert
Jan 06, 2009 | Dell Latitude D600 Notebook
From the keyboard how can i adjust dell latitude D 600 brightness
Hold down the Fn key and press the up arrow several times until it tops out. By default, if you are running on battery power, it dims the display to conserve power.
Oct 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dead Dell D600
You can get the correct adapter on E-Bay for about $20.00. Just search for adapter D600.
Oct 20, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
170 people viewed this question
Alun Cox
