Question about Toshiba e-Studio162D Copier
E162D WHEN YOU HAVE ERROR MESSAGE H4-00- WHERE IS INTERRUPT BUTTON ?? LOCATED
  • Toshiba Expert
  • 1,326 Answers
From the looks of the picture it looks like a Sharp model copier and a H4 code has to do with the fixing ***'y. You problem is one of 4 things - a bad thirmister, a blown thermal fuse, a blown heating lamp, or dirty contacts on the heating lamp. Try cleaning all or replacing all listed and the interupt should be on the to left part of the control pannel. Good Luck..
Posted on Mar 11, 2008
Drum error code
Hi, drum error codes in digital sharp copiers are non-existent. May be drum error symbols or display messages on touch screen types. They differ depending on model but the most common is reset code 24 sub 7 for example sharp 5015 you rest by pressing; C,Interrupt, 0, Interrupt keys and then inputting the above keys. You may specify your copier model.
Dec 14, 2011 | Sharp Office Equipment & Supplies
Pulled out ''new'' 4100 from att box. trying to set up. want to get to 192.168.0.1 to set ppp location. but error message says it is interrupted? am also having att line troubles today. dave j
Push aand hold the reset button to get back to factory default. Some have a default gateway of 192.168.1.254. In your pc under start and in the run tab type [cmd] then [ipconfig] in the box that appears. this will tell you what the default gateway is
Jun 11, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
AR-M205 Error message: H 4 Please help!
H4 error mean heater unite problem
Solve: # -Interrupt -C - interrupt, press 14, press Start key.
Jan 27, 2010 | Sharp AR-M205 Copier
Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Apr 05, 2009 | Sharp SF 2040 Copier
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Feb 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
enter the following code.
cancel -- interupt -- zero -- interupt - the display should switch off then enter 14 and push the copy button- copier should reset if not heater lamp could be blown
May 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Mar 17, 2008 | Sharp AL-1641CS Laser Digital Copier
SYSTEM ERROR H4-00
give this a try, Normally this helps.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 10, 2008 | Toshiba e-Studio162D Copier
Cant get rid of blinking error message, nothing works
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
Toshiba e-Studio162D Copier Logo
110 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
