My tv is cutting off by it self after about 15 mins. It's a 52 inch projection tv. Model #z52s28 serial #511-72320481. It also has a orange light that on with the green power light. The orange light has a light symbol over it
  • dovier99 Mar 13, 2008
    where is the air filter located on my 52 in zenith dlp tv
  • 8,617 Answers
You need to replace your lamp. That indicator is telling you the lamp needs to be replaced.
Posted on Mar 10, 2008
  • Sonny Berry
    Sonny Berry Mar 13, 2008
    It should be located on the side or rear. It will have an access cover with vent holes in it. Different models are located either on the side or in the rear panel.
After about a 40-60 mins tv goes off by itself & orange light blinks for about a minute, stops, then I can turn it back on .15-20 min later it happens all over again.
Sounds like your lamp is overheating...possibly because the fan is not workign or clogged...or the thermal sensor has is failing...google both topics
Apr 19, 2013 | Toshiba 42hm66 42-inch 720p Dlp Hdtv
Hello i have a 60 inch RCA model number d61w20b serial number d505c10h3 manufacturer date DEC 2003. it has started cutting off by its self and the power light will flash 4 or 5 times. sometimes it will...
I suspect that you may have cracked solder connections on the deflection PC board. This is the module that has a red wire coming from the top of a transformer and leads to the front of the tv. I would start with a cleaning of the components, a soft paintbrush and vacuum work well for this. Remove the power deflection module carefully, turn it over and look for cracked solder connections on this PC board. especially near the high voltage transformer. Use a soldering pencil type iron and small diameter solder to correct the issue.
Jul 26, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG 52" Rear projection TV
Probably something wrong with the lamp. Buy a replacement.
Mar 01, 2011 | LG RU-52SZ30 52" Rear Projection...
Tv tuns self off after a few min. lamp light is blinking.
The tv "LAMP" LED light indication flashing or ligting up?Yes,the tv projection lamp live are over.Tv require a new projection lamp.
Jan 08, 2011 | JVC HD-52Z575 52" Rear Projection...
Problem with 52 inch RCA projector t.v
It sounds like the CP150 and or the CP114/120 capacitors need to be replaced, they cost around 3 dollars each and can be found at Radio shack or you can order them from http://servicemanuals.vstore.ca/ and they will send instructions with them.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
Zenith projection tv
Bad Light engine cost was 1900.00 sure it is cheaper now.call UED 1-800-648-6657 for replacement cost.
Oct 12, 2008 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
