Kreisler Lighter Repair
Purchased "pre-owned" Kreisler Lighter(wick & fluid) on Ebay. Appears never to have been used. When removed cotton to check length of wick, the flint chimney just fell out.Need to find out where I can send this for repair.
  • Anonymous Dec 18, 2008
    I have the same problem. I have an old Kreisler lighter that I got as a gift in 1968. I decided to start using it and was wondering how to get it fixed.
  • Peter Hinkle
    Peter Hinkle Feb 28, 2014
    I have the exact same problem as well! It must be a factory fault. Mine had never had oil in it and it was also from the 60's. Did anyone find a solution?
Found out through Colibri Lighter Co,that Kreislers' are no longer made & that there is no one to repair lighter I have
Posted on Mar 11, 2008
Re:Reference #424782 Re:Web order#304867 Re: Date of purchase-8/13/17 Sold to: Rebecca Barnard
sorry but your goung to have to resend your complaint and information to the correct site we are not the seller of products this is fixya a repair forum [[and we cant assist you either since we dont know make model or design of your lighter ]]]]
Sep 06, 2017 | Cars & Trucks
I put a flint and fluid in my old Ronson lighter, and it STILL won't spark.
Hey Vicki, Did you remove all pieces of the old flint?? it needs to be clean.. The spark wheel must make good contact..(could the spark wheel be worn out??)..Some spark wheels have the carbide only on the edges as rings that do the sparking.. some very high end lighters have a solid carbide wheel..$$... make sure the sparking wheel is making good contact..(you may have to stretch the spring that pushes up on the flint..just a little... good luck..
Jul 17, 2017 | Cars & Trucks
I have a ZIPPO and it wont light.How can I fix it?
Does the flint-wheel go around? Is the spark healthy? is the lighter filled with avgas? That should be all you need to know.
If there's a problem, Zippo lighters have a life-time warranty.
Feb 15, 2015 | Cars & Trucks
Wick problems
Turn the bowl upside down and use a match or much better, a cigarette lighter to melt the wax directly below (normally above) the black wick, moving the flame it back and forward. Watch out for hot wax dripping onto your skin!
Then turn the bown over and use a butter knife to scrape the wax above the wick away and remove the wax above and on either side of the wick. You may have to do this operation a few times, but eventually you should be able to gently get the knife under the buried wick and (gently!) prise it back into an upright position.
Don't do this roughly, or you could snap the wick off at its base, it needs to be pretty much out of the wax and softened by the flame before you try to bend it back up.
Then light the cantle and let it burn for ten minutes, until the wax all around it is clear liquid - then blow it out, and after ensuring that the wick tip is no longer glowing, quickly crush a few absorbent paper towels into the bowl and upturn it again. The aim is to allow the towel to absorb excess molten wax, which should preven the wick from being buried under wax again when the candle cools.
Apr 11, 2014 | Heating & Cooling
Where can I buy a new reservoir for my cartier lighter
I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
Jan 29, 2014 | Cartier Tank Solo Watch
Replaced the flint, filled with ronsonol lighter fluid. I do get a sparkfrom the flint to the wick. But it does not light. Tried a match to light wick, it lights and burns. Back to the flink spark, no...
How high is the wick? It can be adjusted by pulling from either direction. Try soaking the cotton til you can see the fluid fill the compartment, or til it drips out the wick. Be sure the fluid has evaporated and the lighter is dry, before you try to re-light it.
Jan 08, 2014 | Cars & Trucks
How do I replace the flint on an old Omega Super Lighter? The old flint appears to be 'corroded' in its tube and I don't want to break it...otherwise the lighter is in great shape.
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 25, 2012 | Cars & Trucks
A couple of days ago my husband spilled a little liqiuid on his Dell Latitude 620 laptop. We dried it out for 24hrs. with a cool fan. Since then the Tab key doesn't work at all and the Caps key appears to...
Hey there , you may need to change the key , at times liquid can affect the rubber cup under the key, and it stops working .. Thats what happened with my Compaq few months ago. I got all those keys changed from www.laptopkey.com (they are an online store that sells replacement keys) i love they service and they price is reasonable
Mar 02, 2011 | Computers & Internet
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
1,309 people viewed this question
 Grubhead
Grubhead
