HP 430 A1 Plotter;5 years old-no previous problems- about 250 plots/annum Recently started plotting lines as "broken", instead of continuous, now has stopped plotting, goes through the motions, but no plot. Have checked connections,cleaned head/cartridge Any suggestions would be most welcome!
    Master:
  • 377 Answers
Have you check if it has a ink, or maybe possible that the ink was totally dry, and your computer cannot detect that it was empty.
Posted on Mar 13, 2008
    President:
  • 1,944 Answers
Did you try resetting the unit by disconnecting from the power for a few hours?
I have plotter HP designjet 500 24" but when plotting from autocad do not plot in gray color, even though layers as assigned in light colors on the plot style.
You need to set up your pen assignments in Autocad, have you done this? ie, Pen1 is 0,25 black, pen2 is 0,35 blue etc,etc. If this is not done you will have problems with colours and line thickness's.
Jun 25, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
MY designjet 430 all of a sudden is not printing straight, but is printing wiggly lines. Any ides on how to fix this?
You can try Print-Quality Plot test to diagnose the problem. Load paper, when ready light up, then press Form Feed and Media Source keys together. After print is done, unload paper.
This plot consists six tests. The third one is Vertical Line Straightness (VLS) test. You can read the HP 430 Service Manual page 6-7, 6-8 and 6-9. These articles will tell you how to correect the problem.
Sep 01, 2010 | HP DesignJet 430 InkJet Printer
Max file size 450c can plot ?
You should have no trouble with the unit as additional buffering will be done in your PC if necessary. These units are a one pass rather than a whole page at a time.
Feb 18, 2010 | HP DesignJet 450c InkJet Printer
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
My plotter is recieving info. but takes forever to start plotting.
Try turning the nesting function off. This can save paper when you are doing high volume printing, particularly with smaller drawings but wil cause extreme delays if there isn't a steady flow of drawings going to the plotter.
Apr 14, 2009 | Computers & Internet
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Why does the plotter use color even if we do not plot in color?
If you print in some CAD programm try the following....
Paper:Plain
Print Target:Line Drawing
Color Mode:Color CAD when the CTB is color and Monochrome when the CTB is monochrome
Resolution:Draft 600
For your situation use CTB monochrome and ColorMode Monochrome.
The print head prints max resolution 2400X1200
Jan 28, 2009 | Canon iPF700 InkJet Printer
Partial plot
if connected via ethernet cable then i believe you have a bad network card, if connected via parrallel, then check to make sure the cable is not over 15 feet in length. also try to uninstall and reinstall the drivers on your computer as they sometimes become corrupt. Good luck!
Aug 17, 2008 | HP DesignJet 750c plus InkJet Printer
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
