Question about Pioneer VSX-D411 Receiver
Pioneer vsa 730
I have stopped gettig any sound from my amp i'm a complete novice so maybe you could please fire some questions at me and possibly help me diagnose the problem
thanks
    Problem Solver:
  • 14 Answers
Try pushing your speaker button untill it says speaker A on or try pressing the button that says signal select.... push it untill auto appears on the screen (You have to do this to every Input eg DVD CD etc Not the radio ) other than that not sure
Posted on Apr 02, 2008
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
How do I reach you?
What do you mean by this question "How do I reach you"?
Apr 16, 2012 | Pioneer Htz-280dvd Region Free Home...
2007 honda odyseey VSA modulator does it impact power steering? had the recall repair completed today drove 30miles lost all power steering fluid vehicle has never leaked any fluid. 57,000 miles work...
VSA is Vehicle Stability Assist and is related to ABS braking.
The power steering issue could just be a series of unfortunate events but it does sound suspicious. I'd try to figure out what caused the fluid to leak and where the leak is in relation to the VSA that was replaced before I took it back to the dealer.
i.e. If the VSA is on the other side of the engine compartment, it's probably not the dealer's fault. If they are right next to each other, something might have happened.
Jan 10, 2018 | 2007 Honda Odyssey
Hello, I have an old Pioneer VSA-1000 home theatre
I have a Pioneer VSA-1000 with what sounds like the exact same problem. It is the world wide model with multi-voltage selectors.
I bought a schematic a couple years ago that I found at www.servicemanuals.net. Cost USD $21 at the time.
Mar 01, 2010 | Pioneer Audio Players & Recorders
I have a pioneer vsa 9500 amp, usually when i turned it on, it has two clicking sounds, now it has only one, and it doesnt have any output sound at all but it has power''
suggest one channel has gone d.c. and the speaker protection relay is not operating because of this. or maybe power on delay cct is not working correctly
Feb 07, 2010 | Audio Players & Recorders
Brand new 2010 Honda odyssey Touring within 40
I can’t be much help on this one (too new for my experience), but your manual will say this (which probably isn’t all that helpful either).
The vehicle stability assist (VSA) system helps to stabilize the vehicle during cornering if the vehicle turns more or less than desired. It also assists you in maintaining traction while accelerating on loose or slippery road surfaces. It does this by regulating the engine’s output and by selectively applying the brakes.
When VSA activates, you may notice that the engine does not respond to the accelerator in the same way it does at other times. There may also be some noise from the VSA hydraulic system. You will also see the VSA activation indicator blink.
The VSA system cannot enhance the vehicle’s driving stability in all situations and does not control your vehicle’s entire braking system. It is still your responsibility to drive and corner at reasonable speeds and to leave a sufficient margin of safety.
On touring models you will also see a ‘‘CHECK VSA SYSTEM’’ message on the multiinformation display if there is a problem with the VSA system.
Without VSA, your vehicle still has normal braking and cornering ability, but it does not have VSA traction and stability enhancement.
The VSA system automatically turns on every time you start the engine, even if you turned it off the last time you drove the vehicle.
I’d get on the Honda people about the problem, especially since you just got the car. I would think that the alarming sounds you are hearing have to do with the unit working the brakes when it shouldn't be, but that's a guess.
Hope this helps some.
Nov 01, 2009 | 2005 Honda Odyssey
Yamaha 5960
Does your reciever use a remote control?
If so, you should be aware that on many recievers and surround amplifiers some of the functions may only be accessible via the remote control (the best way to learn about it is to consult the user manual).
I have a Pioneer VSA-730 surround amplifier and the only way i can change the mix levels for surround/sub/center speakers is by a remote control. My friend had the same problem and, after reading the manual, he discovered that he actually needs to use the remote control to access all functions of the amplifier.
Good luck and best regards
3rq8 (Triarcuate)
Jul 15, 2009 | Yamaha HTR-5960 Receiver
Pioneer VSX-D411 Receiver Logo
448 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
