Question about Dell Inspiron 710m Notebook
Dell Inspiron 710 M mic problem
Hey,
Thanks a lot for your response. I tried all that, but the mic doesn't seem to be working.
I called up Dell support, according to them this laptop doesn't have an inbuilt mic. So I tried attaching an external mic and tested voice recording, but it is still not recording. Can you plz suggest a solution for this?
Thanks,
Pooja.
    President:
  • 2,351 Answers
I can understand your problem Pooja.
I found a fix for you. Click the link below & scroll down to Models with Windows XP and a Sigmatel STAC97 Audio Chip.
http://www.dellcommunity.com/supportforums/board/message?board.id=insp_audio&message.id=29912
Follow the instruction.
Let me know if this gets things going. There's a whole lot of people out there with the same problem. I just don't have a dell 710 laying around to test this fix.
Good luck Pooja!
Let me know how this goes.....
& please vote.
Posted on Mar 11, 2008
Dell 5050 laptop headset mic is not working
Do you have the latest drivers? If you're not sure, go http://www.dell.com/support/drivers/in/en/indhs1/Product/inspiron-15-intel-n5050 and install at least the audiodrivers.
If this doesn't work, go to control panel>hardware&sound>manage audio devices>recording, and see if your headset microphone is listed in there. Choose as default device if it is.
Aug 27, 2012 | Computers & Internet
Can I record stereo via the mic input on my Dell Inspiron 2200 please? Is there any way of getting a high quality stereo recording from a line level input signal without investing in an external sound...
Try using Musicmatch Jukebox,it`s a great program for this and doesnt cost much..has to be pro version to record.You can choose both line and mic stereo recording as well as burn audio cd`s...lots of great features...good luck:)
Apr 12, 2010 | Dell Inspiron 2200 Notebook
The microphone jack of my Dell Inspiron 1100 seems to be malfunctioned. When I plug in a microphone, the other side does not hear anything. I tried several different microphones and none of them worked....
Check if the correct recoding device is selected on sound properties, and verify if mic is mute.Test mic using the sound recording program.
Try to uninstall and reinstall the sound driver.
Perform diagnostic on the audio using the drivers and utility disc. if mic is not working on the diagnostic tool then need to replace the sound card.
Mar 12, 2010 | Dell Inspiron 1100 Notebook
I have a dell 1440 inspiron laptop n series and model PP42L. My inbuilt mic is not working. Speakers are working fine. But i cant talk to others using inbuilt mic. Pl tell me what driver i need to install?...
for that u not have install any driver if your computer in worantty period then call to dell and tell them they fix your problem or not in warranty then also tell them they haelp u better in the inbuilt problem
Jan 25, 2010 | Dell Inspiron 1525 Notebook
In my Dell Inspiron 6400's right speakers are not working. Also the mic is not working. If i connect an external mic its working perfect. Pl help me with the speakers & mic. Thanks a lot !!
Hi. I use exactly this PC. You have to realize the mic is inbuild and not easily seen. Your external mic is also ok. About the right speakers, you'll have to check the connection on the motherboard..most likely one of the i/c has an issue. It is a rugged system and will last. Not to worry
Oct 14, 2009 | Dell Computers & Internet
Distorted sound from new Dell desktop
1. In most cases the problem maybe due to the powersupply. If the filter capacitor or the diodes are not working properly in the power supply, it could give the distortion sound. Use a different powersupply to see if it solves the problem.
2. The mic wire can also catch some hissing noise sometimes. Disconnect the mic wire from the motherboard and see if it solves the problem.
Thanks
Jul 02, 2009 | Dell Inspiron 530 Desktop Computer
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Mic problem?
You will need an external MIC, this system has no built-in Microphone
May 13, 2008 | Dell Inspiron B130 Notebook
Mic not working in 710 M
Hello poo.
Can I assume that your audio is still working? Let's look at a couple of things within your notebook.
1. Open Control Panel than open Sound and Audio Devices.
Click the Audio tab. What should be listed in both playback & recording is device AC97? Click the Voice tab. Same device should be there. Close all opened windows except Comtrol Panel. Open System.
2. Click the Hadrware tab, than click Device Manager.
Scroll down to Sound, video and game controller. Click the + sign to list all devices. Do you see the AC97? Is there any yellow ! points?
3.If you saw the AC97 in all places described & you have no yellow ! point the odds are your internal mic chip is defective.
The only way to fix this is through Dell & they would replace your mainbord in the notebook. However if you wish too I can explain how to uninstall your sound device driver & reinstall the sound/mic driver software just to make sure. Ready?
While still in Device Manager. Right click once on AC97. A small window will display, left click uninstall. Your notebook may ask if your sure. Click yes. Close all opened windows. Re-start your notebook. Right click on your desktop & creat a folder, name it AC97.
We need to go to Dell now. Click the link below.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_710M&os=WW1&osl=en&catid=&impid=
You'll notice the page opends to your Inspiron 710m.
Click the + sign next to Audio. Click on STAC 9750 AC97.
The download page loads. Click the ( Download Now ) button.
You can either Run it now or save it in the AC97 folder you created. Once the download finishes. Close all opened windows.
Last part. Click the start button, than click run. Click Browse & open the AC97 folder click the file R90698.EXE. Click ok.
The driver software will start to install. Once finished re-start your notebook. To test your mic. Open Control Panel, open Sound & audio devices. Click the Voice tab. Click Test Hardware tab. Windows may run it's own little test befor opening the test page.
Now your at Microphone Test page. Follow the instructions.
If you heard yourself through the testing your mic is working.
If the testing failed..... Than we are back to a defective mic.
I hope this has helped.
If you have any more questions feel free to post them here.
Good Luck & kind Regards
Feb 29, 2008 | Dell Inspiron 710m Notebook
Dell Inspiron 710m Notebook Logo
133 people viewed this question
Alun Cox
