Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
WAP54G bricked power led blinking LAN connection shows as not connected
Purchased 2 pcs WAP54G ver1 . Power, connection and Act leds blinking on both units. 30 second reset did not help. 'ping' brought "Unreachable" . Lan port on PC reports that nothing is connected (WAP is connected via crossover lan cable).
Tried to short pins 15 and 16 on Flash , than powered the WAP, ping still unreachable.
Is it bricked? Is it likely LAN chip NS601680 failure? Thanks a lot.
  • 141 Answers
You did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip on the lan of the pc, then ping if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Posted on Mar 11, 2008
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
MediaPack MP114 - 4FXO Doesn't work
Install wireshark on your PC and connect yoour PC directly to the MP, once there power on the MP and see if any bootp/arp message appears on wireshark if nothing shows up, your device is bricked.
Nov 06, 2013 | AudioCodes MediaPack MP114 - 4FXO
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
The power led light is continuously red. But the other two lights ( Act, Link) are green. How do i get the power led light to be green?
Try Resetting it..... Or turning it off for awhile then turning it back on.... Unplug all devices connected to it..... Hope this works :)
Jan 06, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
LinkSys WAP54G non-responsive...
upgrade the firmware and reconfigure it, still if it doesn't works then the router i faulty
Jan 23, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Why link led of WAP54G Linksys is not blink if i install cable on LAN Notebook? i try reset this WAP but still not change. I can't login with IP Thanks.
First RESET your router to defaults settings.Press RESET button for 10 seconds it is in back side of router.
Then connect your router to computer with ethernet cable then you can access it with default link
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Then configure your router again set WAN settings as your interent service provider.
Enable DHCP if you want iip automatic from router.
CLcik on wireless and enable it .Configure your router as WEP or WAP then add code it is your password to connect internet.
Then save and restart router and computer.
Then connect internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 20, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Connection of wiring to board
This link will take you to the download page first download is bios second is manual
Mar 29, 2008 | VIA Jetway V4MDMP MB AMD SKTA MATX/ KM400/...
For dummies
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
855 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
