Question about Frigidaire FDE336RE Dryer
Frigidaire What if the teflon ring is broken on the dryer drum? Can you purchase those rings? brent.plumer@me-engineers.com
  • 5,911 Answers
If this is for the Fridgidaire model you have listed in the heading you used, you can find all the parts you need at searspartsdirect.com. Just type in your complete model number in the search menu and look under the CABINET/DRUM heading. A parts list with illustrations will be provided. I hope this helps you.
Posted on Mar 10, 2008
I have a stackable FEx831CSO. The plastic ring that goes around the dryer drum and holds it in place, broke and fell off. The dryer now makes a terrible sound and the drum is slamming around inside. Can...
It can be replaced. Here's a link to your manual for the dryer, which on the 2nd and 3rd pages has a diagram of it and a part number for you...when you have your part number you can order it either directly from Electrolux or find one on Ebay or another online source....if you have a local appliance shop you may be able to get one there as well....here's the link:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/5995396412.pdf
Nov 04, 2012 | Frigidaire FEX831CS Top Load Stacked...
Drop my marriage ring in to Frigidaire GLGT1031CS
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 03, 2012 | Frigidaire GLGT1031C Dryer
The power turns on but drum will not turn
sounds like ur belt dat gose around ur drum and d motor has snapped easy cheap fix open it up and get d number of d belt and ring d manufactor tell dem d number and order new 1
Jun 26, 2012 | Frigidaire Electric Dryer
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
I have a frigidaire dryer model#FEQB2152FEO. A big white plastic piece broke off around the inside front. It looks white and circular and it seems like it was maybe a seal or ring around the drum?
did you ever get a solution for your problem with your dryer? i have same frigidaire dryer model number and the plastic ring on the front inside just broke off in mine last week and im not sure what to do to fix it.
Apr 11, 2010 | Frigidaire Dryers
Clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
Apr 10, 2009 | Frigidaire Dryers
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Frigidaire dryer makes noise when it tumbles
"spindle" would seem to refer to the rear drum bearing but teflon would describe the front. Have they both been done? Usually when one is worn out the other isn't far behind. Check the idler arm/wheel for wear. Also motors make a sound when the bearings are bad
Jan 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
63 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
