Question about Maytag Atlantis MAV6451 Top Load Washer
Lint marks left on clothing
Hello, I purchased my washer almost a year ago when it was approximately 3 years old. The main problem I am having is that the washer does not seem to have a system to deal with lint, particularly on loads of towels and whites, although on loads of darks, white lines are also evident.
There is no visible lint trap on this washer.
Any suggestions?
Thanks.
Linda from Huntsville, Ontario
  • haywardtec Aug 20, 2008
    1.similar model with similar problem...have run couple of cycle on empty and there doesn't seem to have any lint residue in the tub,of course there won't be any clothing to watch..
    2.have tried to use proper load and water amount.
    3.will be aware that new items do tend to shed lint over a few washing..
    4. not sure with one suggestion to cut down the cycle of washing..can use some explanation.
    thanks.haywardtec
  • Deb303 Oct 29, 2008
    I have had lint residue on my clothing ever since we bought the washer new. It is most frustrating. Recently I have tried using the extra rinse cycle, which seems to help a little bit. But just today, a ton of water leaked onto the floor, so I have an additional problem far worse than the first!
  • 185 Answers
Hello are you washing new items new items tend to create more lint within the first few washes check all pockets to see if there is anything left in them there maybe to much wash action for the size and type of load try selecting a less aggressive wash cycle
Posted on Mar 28, 2008
My dryer is taking twice as long to dry a load of clothes. It is approximately 5 years old.
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 30, 2011 | Whirlpool GEW9250 Electric Dryer
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Front loader leaving black marks
had the same problem. Tried changing the washing powder to no effect.
Jul 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Heavy lint
I had one incident where someone washed an old rug with a rubber base. Took me 2 hours to get all of that out of the pump and drain hose. Access the washer by removing the skin. Read more
Feb 22, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Apr 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Bleach stains
try putting your washer on the highest boil wash this sometimes will stop any of these problems from accuiring again
Jun 12, 2006 | Hotpoint WMM39 Front Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
332 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
