Question about Maytag 24 in. MDB3700 Built-in Dishwasher
No power at control panel
Just installed dishwasher and power up to control panel is present, but the indicator lites donot come on and thier is no activity. this dishwasher has sat for a couple of years in the box, never been used
  • DishwasherDa Apr 20, 2009
    Same description. Breaker is ok but no lights, timer noise,
    nothing
    Novelist:
  • 131 Answers
Corroded / dirty contacts to or in touchpad? door switch?
Posted on Mar 10, 2008
Samsung dmr77lhs dishwasher not turning on
Make sure power is present to the dishwasher from the wall plug, then if that is ok you most likely need to replace the control panel assembly. Cost about $200 US installed on average
Jan 24, 2017 | Samsung Dishwashers
No control panel lites. Washer started then stopped as if power shut off.
Hello John - Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn on the unit. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jul 03, 2013 | Frigidaire Dishwashers
Clean lite blinks on front panel. unable to cancel cycle. interrupted power with no help.
Be so kind to add the model and model number to have more info. For the beginning you might want to try the unplug the dishwasher for 30 min. then try again...but if that does not work, you will need to check the control panel.
Jun 04, 2011 | Dishwashers
Clean lite is flashing
This is an indication that there was a failure to heat the water properly. I have put together some instructions on how to reset the control so you can use the dishwasher and some things to check to avoid this problem again. Follow the link below and let me know if it was helpful.
Clean light flashing
Jul 25, 2010 | Kenmore 24 in. 16014 Built-in Dishwasher
My dishwasher will not start its cycle
Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Is there power to the dishwasher?
electricity ground dishwasher.
Connect ground wire to green ground connector in terminal box.
Donot use an extension cord.
Failure to follow these instructions can result in death,fire,or electrical shock.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
KENMORE 665 MODEL DOES NOT START AND NO LITE INDICATOR VISIBLE WHERE DO I START?
I would start by checking the door lock mechanism. It won't start if the door isn't sending the message to the control panel that it is closed.
Nov 19, 2009 | Kenmore Dishwashers
I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher acts like it isn't getting power.
If you have power to the board and no power out to components then your board has failed. Will need to replace board. Part#154635501 and sugg retail is about$100.
Jun 09, 2009 | Dishwashers
Dvd decoder
its easy.
i can provide u this magic tool.
  1. download it from here.
  2. instgall it.
  3. insert DVD.
  4. run the K-Lite Codec.
  5. choose file.
  6. choose run DVD.
Rate this post as good as u can.
Feb 10, 2009 | Acer Aspire 4520-5582 Notebook
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
112 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
