Agitator and spin cycle not working
When com to agitating cycle hear clickin and no agitation also the same when put into spin cycle
  • apdset58 Nov 19, 2008
    How do you remove the lid switch from a GE WWSE3160A washing machine?
  • Anonymous Jan 31, 2009
    my admiral washer will fill, but not agitate/spin?
  • 3 Answers
I just had the same type of problem and fixed it. The door switch under the lid is not working properly. Mine wasn't working because some lint, etc. got caught around the switch wiring and as the agitator used to spin, it spun a knot around these wires. Over time, this knot started to pull on the wires and one of the wires got disconnected. So, for the time being, I "jumpered" the switch out and can operate that way. BUT, THE SPIN CYCLE WILL CONTINUE TO WORK UNTIL YOU SHUT IT OFF. IT WILL NOT SHUT OFF BY ITSELF (AUTOMATICALLY). ALSO, BE VERY CAREFUL. THE DOOR SWITCH NOW DOESN'T WORK UNTIL YOU WIRE IT BACK IN. THEREFORE, THE SPIN CYCLE WILL CONTINUE UNTIL YOU SHUT IT OFF YOURSELF (NO DOOR SWITCH IN OTHERWORDS).
Good Luck!
Posted on Nov 19, 2008
Motor might need new brushes
Posted on Mar 10, 2008
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Have a circa 1999 Kenmore Three-speed clothes washer (Top Loader) that keeps on agitating regardless of the cycle I put it in. Some cycles do nothing at all, but others (such as Rinse) make it just keep...
The clutch assembly works only to release the basket allowing it to spin during the drain and spin cycles. The drain function works only when the spin function works. If the machine also agitates during spin cycles, then the problem is in the transmission assembly not able to release the agitate gear from the agitate spline in the drive shaft.
Sep 30, 2010 | Kenmore Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Agitator not spinning hear sounds inside the shaft
Hi, this agitator may have stripped all of the internal gears and plastic drive adapters that allow it to preform its actions during the selected cycles. The only solution here will be to replace the agitator and drive shaft as well. you can order a complete agitator kit with all the parts as well. this will fix this issue. Please rate and god bless:)
Apr 13, 2009 | Washing Machines
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
262 people viewed this question
Top Washing Machines Experts
