Question about Panasonic KX TC1743B Cordless Phone
No Link To Base Unit
The Hand Set is not connecting to the base unit so no call can be established from the hand set.
However, base unit is working fine and can make calls with the help of base unit only......
Most of the features are given in Hand Set which cannot be used as the link is not there with the base unit. Please help me , what's the possible problem that the hand set is not connecting to the base unit!!!?
Thanks
Dhiraj
  • 4 more comments
  • DKSinha Apr 10, 2008
    Well, Thanks to every one for even going through my problem. I got few solution.
    Finally I had to go to the authorised service centre. They have changed the Tank Circuit housed in the Hand Set.
    Now the Hand Set is connecting to the base unit, but I found that two new options (functionality) are included in the hand Set and one existing functionality is not present. I need to check this with the service centre, in the mean time if any body found such problem, please let me know. Also, those who are going for the repair, make sure to take the user manual with you at the time of delivery and ceck all the functionality at the service centre itself.
    Thanks
  • friend123 Dec 11, 2008
    the handset has no link to the base. the base is working and the calls can be answered using the base
  • Anonymous Mar 14, 2014
    model ge26963ge2-c..message on hand set "no link to base" and I can not find an online manual..
  • Anonymous Mar 18, 2014
    model# LS6245
  • Anonymous Mar 27, 2014
    reset the unit and no info on the base hand set display
  • Anonymous Mar 31, 2014
    can not connect the hand set with base station
I am having the same problem!
Posted on Apr 08, 2008
The in use/charge indictor light does'nt come on when i put phone on it. I just brought a new battery.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Sep 03, 2011 | Uniden Cordless Phone
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Jul 27, 2009 | Uniden TCX905 Cordless Accessory Handset...
Sony SPP-A946 base unit intermittently charges the hand set.
Clean the contacts on the handset and base that charge the battery.
AL
Mar 17, 2009 | Sony SPP A946 Cordless Phone
The phone ( sub-unit) links to the base on and off from time to time. How can I do ?
Sounds like the RF (radio frequency) module may be bad. If your battery is really old it could also be the problem, especially if the problem is more likely to happen after the phone has been off the charger stand for some time.
May 02, 2007 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX TC1743B Cordless Phone Logo
661 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
