Unable to see wireless modem in my laptop
Had to reimage my laptop but now i can not see my linksys wireless modem
    Genius:
  • 3,587 Answers
You'll need the drivers from the manufacturer..check this link to see if it's one of these
Posted on Mar 10, 2008
Can't connect to the internet with ethernet cable or wireless
ethernet jack may be fried.. Go to device manager and see if its disabled or non existant.
Jun 05, 2014 | HP Pavilion m7480n (882780389410) PC...
Tip
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
Receiving wireless signal but unable to connect to the Internet
you have to set your router into mixed.....and set your gateway into LAN & WIRELESS...
Jul 08, 2010 | Linksys Cable Modem
I am unable to use my internet due to the router. I can connect from the modem to my laptop but unable to connect from the modem to the router. What can I do to fix it?
You will need to check the wireless settings of the router
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 13, 2010 | Linksys WRT110 Wireless Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
Unable to setup wireless print server with wireless router
The issue was the wireless print server not properly connecting to my home network and thus being unable to see my modem/network. This was because my linksys wireless print server generates its wep key with a different algorithm than the Motorola surfboard SBG900, this also explains why when I was using my old linksys wireless g router, things worked without any issue (same wep key algorithm). Once I figured out how to manually configure the print servers wireless settings and manually enter the wep security settings I was able to connect to my network and the configuration found the print server and I was able to finish setup.
Nov 27, 2008 | Linksys WPSM54G Print Server
No Installation CD for Wireless-G Notebook Adapter
Hello! It is possible to install it without the CD< but not easily >You will need to, On a separate computer, Go to Linksys.com and download the drivers, then just burn them to a CD< or Put them on a flash drive, and install it on the laptop. Unless the laptop has a Ethernet port, then just connected the computer to the linksys router VIA Ethernet to download the drivers.
Nov 24, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
110 people viewed this question
Alun Cox
David Payne
David Payne
