Question about SanDisk Sansa e250 MP3 Player
Recovering Space? i had about 345 songs and 10 videos on my sp3 player and all of my songs just started urning into bad tracks and then my videos said "convert with sandisk media converter". i deleted everything that i could find and when i went to reload all of my songs, it said that 900 something of my MBs were full when under computer, it was empty of everything. what do i do?
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
Hello. I believe I have a Sansa e250, but I don't
Copy all the songs to your computer AND CHECK THEM.
Format the mp3 player and reload Drop and Drag use your explorer 2 windows, 1 the players music the other saved music folder
Apr 06, 2010 | SanDisk Sansa E280 MP3 Player
My sansa fuze 4 says not enough room for music db please free 90mb what does that mean
There needs to be some space for the part that finds and tracks the songs. There are too many songs/pictures/video on your Sansa. Remove some. Its always good to have some extra space. Don't fill it up completely. Always leave 100megs free when loading the player.
Mar 21, 2010 | SanDisk Sansa Fuze MP3 Player
Need to delete pictures and video thats was already on system
You have to delete the files from within Windows Media Player itself. You can also delete them using Windows Explorer.
Here are some helpful file son deleting using Windows Media Player:
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
-Tha Mp3 doctor
Jan 06, 2009 | Philips SA3025/37 Flash MP3 Player
Bad Track
You will probably have to reformat the player, but the "bad track" message could also be caused if the songs you are trying to download have an expired DRM license.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa E280 MP3 Player
I have Hitachi AX-M83 system. While deleting a song from USB stick, it asked "Del File" Now my question is how many songs does a file have? Because USB stick showed 31 tracks stored,...
The number of songs you can store has to do with the size of the USB. Now the file itself has a size and make sure your system has enough space for the file.
May 04, 2008 | Audio Players & Recorders
LOST SPACE!
same thing happened to me it still doesn't work and mine is supposed to hold 500 it only holds 150
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
I could listen to some songs
Prob need to format the player
1. put player in msc mode (settings menu under USB)
2. go to my computer and rightclick on sansa
3. format box: choose quick format
4. format complete, allow player to stay connected to computer for 10 mins
go to sandisk.com and under downloads, download the updater to keep this from happening again, put the updater on your computer so each time you plug it in, it will look for updates
make sure you do not put questionable files on the player such as itunes or mp4, as they will "bad track"
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
Problems with Sansa e250
-Tha Mp3 Doctor
Aug 16, 2007 | SanDisk Sansa e200 MP3 Player
My sansa keepz bringing up songs as bad tracks or unknowns then doesnt play them
i'm having this problem too. what i think is happening is you took the song off the player. However, the it is not completly off of the player. i.e. song info still on their. song name, artist, album ect. i just took everything off of my player. it says 1/467 songs on their but all say bad track. thats the problem now about that solution, i'm looking into it. but ya if you have any problems. hit me up at headshot347@gmail.com or MXRIDER007R on aim.
May 13, 2007 | SanDisk Sansa e250 MP3 Player
BAD TRACK FOR EVERY SONG
Hi tooky. Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info. One solution would be to format your player in Windows Media Player (version 10 or 11): 1. Make sure your player is in MTP mode by navigating the menu as follows: Menu > Settings > USB Mode You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure". 2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt. 3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature. You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well): For standard E250 or E250R "Rhapsody Series": http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Make sure your player is set to MSC mode, or "Rhapsody" Mode The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files. I hope this helps. There are other procedures available but these might actually make your player work normally again. Hoping for the best :)
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
