I have a belkin adapter which connects my 2 pcs together sharing a mouse, keyboard and monitor. I recently bought an acer slimline 22 inches monitor to replace my old bulky monitor. However when I connect in the same way as before to my new monitor, the monitor does not work i.e. the screen is blank and no power light comes on - so there appears to be a problem; can you help?. Incidentally I made sure there is nothing wrong with the monitor - I tried to connect it to my laptop only (not 2 pcs together) and it seems to work. Your comments would be much appreciated - thanks. Fatima
  • tima1 Mar 13, 2008
    I have been away for a few days. However, I am going to try again today - maybe there is a loose connection. I will let you know how I got on.
    Incidentally, if indeed there is a loose connection does it mean I have to buy a new belkin adapter (which comes attached with power cross loop cable; one part needs to be plugged into the pc and the other into the monitor) or can the loose connection be fixed some other way?
  • tima1 Mar 14, 2008
    There is no loose connection as the old monitor is powered up using the belkin router to connect 2 pcs together. This is not the case when the acer TFT monitor is replaced and connected the same way. The resolutions meet the specification of the acer monitor.
    The problem still remains but thanks for trying.
  • 101 Answers
Try changing the refresh rates and resolution on the pc..
do u have a driver for that ??
and check the cable for loose connections !!
hope this works !!
Posted on Mar 10, 2008
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
Microsoft Keyboard (1045) doesn't work with new Samsung Monitor
Keyboard and mouse have no connection with Monitor
Since keyboard and all are linked with mother board
so firstly i suggest you yo check the wireless connections are ok
Now reinstall the software packages that came with the keyboard(And drivers)
i hope this will help you
Mar 23, 2009 | Microsoft Wireless Notebook Optical Mouse...
Components not recognised automatically with Belkin Switch2
This is not quite a solution, but a workaround. Take a USB cable extender and intercept the 5V supply wire in it (normally red) with a push to break switch. When you have powered up the PC, push the switch and the KVM will then work (same as your unplugging but much easier to do ). Switch bought on Ebay for 0.99GBP. Belkin tried to insist that I had my laptop plugged in and working if I wanted to use my desktop.
Feb 08, 2009 | Belkin F1DF102PEA 2-port KVM Switch
PS/2 to USB adapter Issue
go to Control panel, click on your mouse icon and set the settings for your mouse
Jan 22, 2009 | Foxconn 6100K8MA-RS Motherboard
PS/2 to USB adapter
does windows recognise the new hardware and install drivers for it when you plug the wireless sender in to the laptop ?
try opening up device manager and see if the deive in question has an exclamation point over it , if ti does remove and reinstall
hope this helps
Dec 31, 2008 | Belkin Wireless Keyboard/Optical Mouse...
Belkin 2-Port KVM Switch
It is compatible with a wireless mouse, as long as it is a PS2 mouse.  if it is USB you could try using a converter, but it may not work.
Nov 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
Wireless network between vista & xp
Open Windows Explorer, and then locate the drive or folder you want to share. Right-click the drive, and then click Sharing and Security. To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer. To change the name of your folder on the network, type a new name for your folder in the Share name text box. This will not change the name of the folder on your computer. To allow other users to change the files in your shared folder, select the Allow other users to change my files check box.
Oct 06, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
