Question about Samsung HCM4215W 42" Rear Projection Television
Color alignment problem
In my Samsung HCM4215W I replaced the color module with : Brand
Description
Part Number
Samsung
Samsung BP95-00142E Convergence Board
BP95-00142E
from partstore.com but the problem was not corrected; but it did change the problem. Did I use the correct part? The problem seems to be that the red and green are aligned but the blue is out of alignment. When I changed the part, I had a green that was out of alignment and was unable to adjust it.
  • 4 more comments
  • RobH-NC Mar 10, 2008
    Right now, I still have the old board back in, I can align the red to the green in all places. I can't align the blue in the center and left side. With the new module I can move the blue and red as needed but the green is out of whack and, as you stated, the green is not an option to move. How do I put the unit into "service mode".? Is it possible I installed the wrong part?
  • RobH-NC Mar 14, 2008
    OK, FD102 is reading open; FD101 is around 7 M-Ohm.
  • RobH-NC Mar 15, 2008
    ok the new board is a bit different (but I was reassured that it was the correct replacement part from partstore.com), in the places where FD101 and 102 are; it is labeled J127 and J128 and they are both just straight wires from the appearance. Do I still use those two?
  • RobH-NC Mar 17, 2008
    I replaced both ICs and the two FDs with the jumpers. The picture was better and I was able to manually adjust the alignment but there is still a slight bowtie in the center so there is more i need to do. I will check the part numbers and post them later.
  • RobH-NC Mar 29, 2008
    The old ICs STK392-040 and sub#B2G08. The new ICs are also STK392-040 but sub# is B7k05.
    Yes the bowtie seems to be all colors. basically narrow in the center wide on the outside.
  • RobH-NC Apr 02, 2008
    OK, in service mode it is clear that the green is distorted. Grid appears contracted in the middle giving the appearance of being "farther away" than at the edges. This resulted in the bow; I guess i had adjusted the other two to match it. The blue and red grid are perfect. The green does not move up/down only moves side to side. I can move the others in full or line mode in any direction. Thanks for sticking with me.
  • 31 Answers
You will need to put the unit into wahts called service mode because it will have to totally realigned since you change the whole module you changed the chip that had you stored memory setting for convergence called an EEPROM. here in the shop I would unsolder the old EEPROM and put it on the new BOARD. Also on most models you don't have adjustments for the green you have to move red and blue to match green. Imay want you to describe again to me what you can adjust now with the new board in the unit can you move all colors left right and up/down
Posted on Mar 10, 2008
  • 3 more comments
  • JAMES JACKSON Mar 10, 2008
    do you have a meter you can check for me on the old board you have in now 2 pico fuses location# FD101 AND FD102. they should read shorted. if 1 or both of these are open you may just want to change the convergence ic's that are on the new board to the old board that is ussually all that is wrong and you would not nee to do much if any realignments. but first let me knnow if you can if these fuses are open
  • JAMES JACKSON Mar 14, 2008
    both of those are circuit protectors same as a fuse, The option you have since you have the new module is to remove the parts you need from the new board and replace them on the old board which has your eeprom settings still stored in it so your adjustments are still their and may only need a touch up. you should see 2 big STK IC'S mounted on large metal heat sinks. these are whats bad and since u have both fuses open(meg ohm is open/bad also) both of them are bad. after that change the circuit protectors at this point you may or may not have some resistors open these are the parts with colored bands around the part sometimes they will be burned or discolored when thier bad. usually the ones that are bad are nearest the stk ic's and will read 2.2 or 3.3 or maybe 4.7ohms. you can try just changing the stk's and fuses and see if that is all you need if youcan adjust everything your ok if not you have some resistors open
  • JAMES JACKSON Mar 17, 2008
    very strange that they would take out fuses and put jumper wires in their place, the jumper wires would not offer any protection from the IC's shorting out. I would rather see you put 2 new circuit protectors back in but you could use the jumper wires if you have no other choice. your short will bw gone after you change the 2 big IC's. Look around on the new board and see if they have 2 circuit protectors on the new board just in different location. also since you seem to have some differences ion the new vs old board make sure that the 2 IC's we are changing are the same on the new board as the old board. if not let me now the actual numbers on the parts so I can determine if they sub/cross to each other.
    is the bowtie effect the same on all 3 colors?
  • JAMES JACKSON Mar 31, 2008
    OK here is what I think on this model should put you in technician's service mode. NOW KEEP THIS IN MIND THERE ARE CHANGES YOU CAN MAKE IN HERE AND THE TV WILL SHUTOFF AND YOU WILL NOT BE ABLE TO TURN IT BACK ON WITHOUT CHANGING THE EEPROM SO MAKE SURE YOU ARE IN THE CONVERGENCE/GEOMETRY ADJUSTMENT AREA. Ok also when finish alignments don't forget to save new data.--service mode below:
    With The Set Running Press Mute, 1, 8, 3
    Add/Erase Saves
    7,8,9 Turn Colors Off
    Bottom Number Row Selects Color
    4 Toggles Line Mode On And Off.
    Menu And S Mode Move Cursor.
    sounds like you just need to adjust top and bottom "BOW"
    good luck
    James
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
My Samsung HCM4216W is displaying a distorted picture what can cause this? Also, the color is diminishing. It has sort of a dip at the top of the display and the picture is more cyan in color.
Covergence ICs you can replace both of them or whole board Encompass Parts has board 1-800-638-3328 and Mats Electronics has STK ICs
1-800-628-1118 ICs are big black ICs will have part number on them STK392-020
Mar 23, 2010 | Samsung HCM4215W 42" Rear Projection...
Changed color wheel on samsung dlp. now getting a blured blue screen which covers 75% of screen.
Sometimes on the DM board of the light engine it has a small black jumper that sometimes needs to be removed and colors are restored, sometimes might need adjustments in service menu.
Oct 28, 2009 | Samsung HCM4215W 42" Rear Projection...
HLT5075SX/XAA DOESN'T WORK EVEN AFTER REPLACING THE LAMP.
If you are not hearing a whining noise coming from the color wheel then you have a bad Ballast. Part# BP47-00037A.
Jul 17, 2009 | Samsung HCM4215W 42" Rear Projection...
Blinking power light after replacing convergance board.
Your chips are most likely bad or you bridged the soldering.
For all others with similar convergence problems
This is a common problem.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Red Convergence Issue( Samsung HCM4215W)
Bad chips or faulty soldering.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W pink/green and wavy
Practice visual acuity technique!Check signal PCB for CRT coolant leak.Cleaning circuit board may restore normal operation,but one or more leaks will cause problems to re-occur.Change leaky CRT(s).
Dec 19, 2006 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
151 people viewed this question
Jerry Greenberg
Jerry Greenberg
