Question about Intel Motherboard
3 AGP pins smashed down
Is there any way I can repair 3 AGP Motherboard connector pins smashed down?
  • BS UCLA Electrical Engineering
    Thanks for the help, I managed to get the 3 pins up (took an hour of surgery) but then cover the pins with a tin sheet of plastic that I could pull out after carefully inserting the AGP card. Not sure if it was worth the effort, but it worked! I will never install a card so carelessly as I did again. I have finstalled literally thousands of cards with no problems but have been getting more and more careless. Thanks for the insight to watch for re-smashing. Take Care!
    Genius:
  • 1,554 Answers
Not very likely even if you manage to pull the up and flatting them .
they will crumble again when inserting a card.
Posted on Mar 15, 2008
Diagram of t2878
Diagram? I don't quite follow. However let me post this information to see if it qualifies as what you seek.
1) The eMachines T2878 Desktop PC uses an FIC AU31 motherboard. Also known as K7M-NF18G.
(FIC is First International Computer {Inc)
This is a link to a free motherboard manual, for the FIC AU31 motherboard,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
5th file down on the left side. Click right on AU31
This is a Zip file. (A Zip file is used to send large amounts of information)
Click on the circle to the left of Save File, if there is no green dot in it.
Now click on OK.
A small window will come up on the left.
In the wording at the top of this small window, will tell you where the file will download to.
It may have Desktop, or MY Documents, or Downloads, in the wording.
You may wish to write it down.
Desktop:
The zip file will be on your desktop screen
My Documents:
Click on Start, then on My Documents
Downloads:
Click on Start, then on My Documents. DOUBLE-click on Downloads.
When you see the file name DOUBLE-click on it.
(Yellow folder icon with a zipper on it, and AU31_manual next to it)
On the far left at the top, click on Extract all files.
Now click on Next, Next, and Finish.
After you click on Finish you will see the file name next to a red Adobe PDF icon. DOUBLE-click on it.
There is the motherboard manual in PDF file form.
2) Motherboard Diagram; (Pertaining to the technology used for your eMachines T2878 computer),
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of a computer.
Supports the Processor, Ram Memory, and High-speed graphics.
Note*
AGP and PCI Express are High-speed graphics.
A graphics card inserted into a PCI slot, or using Integrated Graphics, is NOT high-speed graphics.
The Southbridge chip handles the slower capabilities of a computer.
The PCI bus, IDE bus, SATA bus, USB, Ethernet, and Audio. (Sound)
3) The FIC AU31 motherboard uses an Nvidia nForce 2 motherboard chipset,
http://www.geeks.com/details.asp?invtid=AU31-WB&cat=MBB
Nvidia nForce 2 IGP for the Northbridge chip, and Nvidia nForce 2 MCP-T for the Southbridge chip.
Click on the motherboard photo to enlarge.
The white square socket at the top is the Processor socket.
(Socket A. Also known as Socket 462)
Under the Processor socket is a black Heatsink. Looks similar to a meat tenderizer. Underneath this heatsink is the Northbridge chip.
(The heatsink is glued to the Northbridge chip with a type of thermal glue)
The Southbridge chipset is under the ram memory slots. The large square chipset. (To the right of the white PCI slots, and to the left of the CMOS battery)
Specifications of the Nvidia nForce 2 chipset,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#nForce2
4) Basic layout of the FIC AU31 motherboard;
A) The three long white expansion slots at the bottom, are PCI slots
B) The shorter brown expansion slot above them, is a graphics expansion slot.
It is AGP, and 8X. (AGP 8X)
Uses AGP 8X graphics cards.
C) The two long Black slots to the upper right are Ram Memory slots.
Slot 1 (DIMM 1) is the slot closest to the Processor.
If you just use one ram memory module ('Stick'), it MUST be installed in Slot 1.
(Supports DDR Sdram ram memory at either 200MegaHertz, or 266MHz, or 333MHz, or 400MHz. This is PC1600, PC2100, PC2700, and PC3200, respectively)
D) The white connector socket to the immediate right of the ram memory slots, and has two rows of 10 socket holes, is a 20-pin ATX main power cable connector.
E) To the right of the 20-pin ATX main power cable connector, is the blue 40-pin IDE connector for the Harddrive.
(39-pin actually. One pins is omitted. Uses a flat ribbon cable)
F) Above the harddrive connector is a 34-pin Floppy Drive connector. It is black in color.
G) To the left of the Floppy Drive connector is the optical drive connector.
(Also 40-pin)
H) Uses a Realtek ALC650E audio chipset
I) Uses a Realtek RTL8201BL Ethernet chipset
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 02, 2011 | E-Machines eMachines Desktop PC
What is the best graphics card for my SR1502HM compaq computer.
Scroll down to the bottom of the page, and observe the motherboard illustration, and photo,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257657&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=501966
The best graphics card expansion slot on your motherboard is an AGP slot.
(The motherboard also has 3 PCI expansion slots)
It is an AGP 8X expansion slot.
[Scroll back up in the chart to the heading > Graphics connector (AGP) - 1 AGP 8X ]
These are a few examples of AGP 8X graphics cards that will work.
1) Good
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4803129&CatId=2234
2) Better
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5367566&CatId=3669
3) Best
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=2234
Nov 28, 2010 | HP Compaq Presario SR1502HM PC Desktop
My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
Here are the specifications for the motherboard: Processor
- AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
- FSB 200/266/333MHz
Chipset
- North Bridge: NVIDIA nForce2 IGP
- South Bridge: NVIDIA nForce2 MCP
- I / O Chip : Winbond W83627HF
Memory
- 3 DDR Sockets:
DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
Expansion Slots
- 1 x AGP 8X/4X slot (1.5V Only)
- 3 x PCI slots (PCI 2.2 compliant)
IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
Onboard I/O Connectors
- 1x Floppy Connector
- 2x USB 2.0/1.1 header (4 ports USB cable optional)
- 1x CD_IN header
- 1x COM Port header
- 1x S/PDIF in/out header (S/PDIF in/out cable optional)
- 1x CPU fan header with fan rotation detection function
- 1x System fan headers with fan rotation detection function
- 2x 5 pin system panel header (Intel spec)
- 1x 3 pin Power LED header
- 1x 4 pin Speaker header
- 1x Front audio header (Intel spec)
- 1x Case Open detection header
- 1x Wake on LAN
- 1x 4 pin TV-Out header
So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
If you need further assistance, just leave a comment. Thank you for using FixYa.
Apr 19, 2010 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Since I have been unable to find a User Manual for a Chaintech 9BJA motherboard, does anyone know where I can find the pin layout for the 9x2 Front Panel Connector to connect the case front panel...
I found the Motherboard Manual for it. It comes as a Zip file.
At first my zip extractor seemed to have problems with it. Unzipped it anyway.
Comes as 8 small files. (Sheesh!)
I'll give you the link to the download website. I'll also tell you how to connect up the Front Panel header, just in case you have problems unzipping the files like I did!
Download website for the Motherboard Manual for the Chaintech 9JBA.
http://www.elhvb.com/mobokive/Archive/Chaintech/manuals/index.html
Scroll down the list on the left. In blue it's -> 9jba0 <- (No, I don't know what the zero is for)
Takes you to another page. Under -> Filename, click on -> 9jba0.exe <- It's 4624KB in size.
(That's about 4.6MB's. Not very big)
It will ask "Do you want to save this file?" Click on Save.
Then the Extraction Wizard will come up. Click on unzip.
If you don't have your downloads going to your My Documents folder, it will pop up these 8 files on your desktop. They're PDF files, and you have Adobe Acrobat Reader on your computer, so it will open these files.
Now, in case you can't download these.
Not to offend, but the manual is a piece of junk. Good thing I've got years of experience with computer motherboards, and reading crappy motherboard manuals.
Hardware setup is in file -> 9bja0-2.pdf (By the way. You can enter the CMOS Setup utility by pressing the Delete key, right after the Chaintech 'splash screen'. { Logo screen)
I am looking at file -> 9bja0-1.pdf now.
I had to expand the PDF file by 800% to see the Front Panel Header. IT IS ->16 pins. 2 x 8
Orient the motherboard, so we're on the 'same page'. Processor is up towards the top, expansion slots, (PCI) are to the left. The Front Panel header is down to the very bottom right corner.
It has -> FTP under it. To the left of it is another header. It has Smark Card under it. (No I didn't misspell it. That's what the mobo manual states) Do Not connect anything to the pins in the Smark Card area.
The Front panel header going lengthwise, there are 7 pins on top, 8 on bottom. Across the top there are 3 pins, NO pin, then 4 more pins.
Pin 1 is on the Bottom all the way to the Left. It doesn't state if it goes Pin 1, 3, 5, 7, 9, 11, 13, and 15,
for the Bottom row of pins, or 1, 2, 3, 4, 5, 6, 7, and 8.
I'm going to number the pins across the Top as Pins, 2, 4, 6, NO Pin, 10, 12, 14, and 16.
Bottom row of pins is Pins 1, 3, 5, 7, 9, 11, 13, and 15.
Top Row
Pins 2, 4, and 6 are for the Power On LED light. The Positive attaches to Pin 2.
There is No Pin 8.
Pins 10 and 12 are for the Green Power switch. Suggest you DON'T connect anything here.
Pins 14 and 16 are for the Override Power Button. Suggest you DON'T connect anything here.
Bottom Row
Pins 1, 3, 5, and 7 are for the internal speaker. Pin 1 is for the Positive connection.
Pins 9 and 11 are for the Power On switch.
Pins 13, and 15 are for the HarDDrive activity light. Pin 13 is for the Positive wire.
More info:
This Chaintech motherboard uses Pentium 4 processors, that use a Socket 478. The processor FSB is 400MHz. (You can't use P4's with a 533MHz FSB, nor ones that use a 800MHz FSB. Go to Wikipedia.org
In Wikipedia's search bar, type -> List of Intel Pentium 4 Microprocessors <-
Look through it, and you'll see P4's that use the Socket 478, and have a 400MHz Front Side Bus)
Has the Intel i845 Northbridge chip, and the ICH2 Southbridge chip. This is the 'motherboard chipset'.
Actual name is Northbridge/Southbridge chipset.
Has 3 ram slots. Maximum TOTAL Amount of ram is 3GB. Maximum Amount for EACH ram slot is 1GB. Uses PC133 ram. (SDR Sdram. Commonly just known as Sdram. ALL ram from Single Data Rate Sdram up to DDR3 Sdram, IS Sdram. That's why just stating just ->Sdram is a misnomer!)
Has to be Low Density ram, and Non-ECC.
The AGP graphics slot is a Universal AGP slot. BUT, it only uses AGP 2X or AGP 4X graphics cards.
They must be able to turn down to 1.5 volts. Using a 3.3 volt AGP graphics card, will result in System Boot up failure, malfunction, etc.
Uses IDE harddrives. (IDE is also referred to as EIDE, ATA, and PATA)
It's an ATX form factor motherboard.
Apr 18, 2009 | Chaintech CT-9BJA Motherboard
Just wanted to know if the mother board 865GM3-LS supports 1Ghz of AGP graphics card..
Motherboard has a AGP 8x ( 1.5 V/ 0.8 V ) slot.
Check the specs on the graphics board you are going to install. Make sure that it meets these specs.
Here are the specs for your motherboard: General Product Type Motherboard Form Factor Micro ATX Width 24.5 cm Depth 24.5 cm Compatible Processors Pentium 4, Pentium 4 Extreme Edition 64-bit Processors Compatibility Built-in Processor Socket Socket 478 Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz BIOS Type Award Storage Controller ATA-100, Serial ATA-150 Processor Installed Qty (Max Supported) 0 ( 1 ) Memory Supported RAM Technology DDR SDRAM RAM Installed ( Max ) 0 MB / 2 GB (max) Supported RAM Speed PC2100, PC2700, PC3200 RAM Features Two DDR channels Video Graphics Controller Intel Extreme Graphics 2 Video Memory Shared Video Memory (UMA) Audio Audio Output Sound card Signal Processor Intel 865G Audio Codec Realtek ALC655 Sound Output Mode 5.1 channel surround Compliant Standards AC '97 Telecom / Networking Networking Network adapter - Realtek RTL8100C - Ethernet, Fast Ethernet Features BIOS Features Hyper-Threading Technology Expansion / Connectivity Expansion Slot(s) 1 ( 1 ) x processor - Socket 478
2 ( 2 ) x memory ( 2.5 V ) - DIMM 184-PIN
1 ( 1 ) x AGP 8x ( 1.5 V/ 0.8 V )
3 ( 3 ) x PCI ( 3.3 V/ 5 V ) Storage Interfaces Serial ATA-150 - connector(s): 2 x 7pin Serial ATA
ATA-100 - connector(s): 2 x 40pin IDC Interfaces 1 x storage - floppy interface - 34 PIN IDC
1 x serial - RS-232 - 9 pin D-Sub (DB-9)
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
4 x Hi-Speed USB - 4 PIN USB Type A
1 x audio - line-In - mini-phone stereo 3.5 mm
1 x audio - line-out - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5mm
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
1 x mouse - generic - 6 pin mini-DIN (PS/2 style) Additional Connectors (Optional) 4 x Hi-Speed USB Miscellaneous Software Included Drivers & Utilities Compliant Standards Plug and Play
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 10, 2009 | Computers & Internet
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
Problem
there are many things that can cause this, first obvious causes would be bad ram, dead mainboard or hard drive.. i say dead motherboard due to the fact you say there is no post beep on startup, easy way to tell, remove all the ram, and turn it on, if it squeels at you, you know the motherboard still at least is somewhat operational, next thing try replacing the ram.
Feb 28, 2008 | EliteGroup PT800CE-A Motherboard
AGP
You can add an AGP Graphics card if an AGP slot (Not White) is provided on the motherboard not a connector just to clarify.
Dec 01, 2007 | AOpen ADD Card AGP Graphic Card
Intel Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
